RV.Net Open Roads Forum: Check this if you've bought a used RV recently
 > Check this if you've bought a used RV recently
bucky
Raleigh metro
Posted: 11/17/20 04:34am Link  |  Quote  |  Print  |  Notify Moderator
I was putting the dog out yesterday and heard the infamous beep from the 5er. Ah, the old dead battery in the dinner is ready alarm.
I go find and test a 9V battery and pull down the alarm. There wasn't even a battery in the thing.
The beep was the LP/propane alarm near the floor.
My fault for not testing the alarm in January when we bought it but it never crossed my mind. Go check yours today.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
gbopp
The Keystone State
Posted: 11/17/20 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Good point. But, you need to check them when you buy any RV, new or used.
As we know, just because an RV is new doesn't mean there are no problems.
BurbMan
Islip, Long Island
Posted: 11/17/20 05:35am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, those LP alarms have a lifespan and need to be replaced at some point. Easy to change, two screws to take it out and two wires to connect it. Sometimes cleaning aerosols will contaminate the sensors and cause them to randomly go off and then they're ready for the trash heap.
I will say check, check, and check again that you don't have a gas leak before you assume the sensor is bad!
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
schlep1967
Harrisburg, PA
Posted: 11/17/20 05:36am Link  |  Quote  |  Print  |  Notify Moderator
Odds are the LP/Propane detector runs off of you RV Battery. If your unit is not plugged in to keep the battery charged or on a solar charger, that detector and other parasitic draws will drain the battery. When the battery gets low, the detector chirps. You are going to want to charge that battery before freezing temps hit.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
dodge guy
Bartlett IL
Posted: 11/17/20 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Ok people. His LP alarm is not bad. He is saying his smoke detector never had a battery in it. He thought the beep was from the the smoke detector, but without a battery it couldn't beep.
Good find, glad you found it before it's too late!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
schlep1967
Harrisburg, PA
Posted: 11/17/20 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Yep. I was just addressing the issue he didn't know he had.
Lynnmor
Red Lion
Posted: 11/17/20 06:12am Link  |  Quote  |  Print  |  Notify Moderator
Don't they put batteries in at the factory? [emoticon]
RAS43
Littleton,CO
Posted: 11/17/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
It is a used unit per OP.
fj12ryder
Platte City, MO
Posted: 11/17/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Our smoke detector never had a battery in it either. However it was wired into the battery like the CO detector.
Howard and Peggy
"Don't Panic"
valhalla360
No paticular place.
Posted: 11/17/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
The DW tests the smoke detector daily while camping.
As a bonus, it usually means dinner is ready.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
