RV.Net Open Roads Forum: Fifth-Wheels: awning
 > awning
cpaulsen
Oregon
Posted: 11/17/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Went to open my awning with the inside switch(Solera 18'.....and nothing worked. Fuse is good but there is a plug by the awning rail that is not hooked up and have no idea where it pugs in at.. 2018 Montana HC
cpaulsen
Flute Man
Payson, Arizona
Posted: 11/17/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Your 12 V battery may be low.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
cpaulsen
Oregon
Posted: 11/18/20 06:03am Link  |  Quote  |  Print  |  Notify Moderator
Battery is good...
MFL
Midwest
Posted: 11/18/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Has it always worked and just quit? It would seem if something in area of awning motor is unplugged, that would be the issue. Can you post a pic of this plug?
My awning is a Dometic, and has a plug connection in the arm of awning. If unplugged, I know mine would not work.
Jerry
schlep1967
Harrisburg, PA
Posted: 11/18/20 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a multimeter or test light? You could check that plug for voltage when you activate the switch. That may tell you that plug is for something else (like awning lights)if there is no voltage to it when you push the switch.
And you could also use them for the next step that will be to test for voltage at the awning motor.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
SWoop2247
South Texas
Posted: 11/18/20 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Same here. I have a dometic and the plug is in the arm covered by a plastic strip. Unplugged mine won't work either.
The plug would be my first.
If that doesn't work grab a meter and start chasing 12V
2014 Dodge Ram 2500 4x4 6.7L Cummins
24K Curt Slider
2013 Heartland Sundance 3200RE
cpaulsen
Oregon
Posted: 11/18/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Has always worked.......but when we got to our new destination....I pushed the switch and nothing happened....then saw a square plugup by the awing tube.....touched it fell off......looks like a plug of some sort......like a matching plugthat something plugs into.....will contact Lippert/Solara and see if they have an answer
MFL
Midwest
Posted: 11/18/20 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
IIRC, my plug is a male/female, when put together with plug mate, female/male appears to be a smooth one piece connection.
Jerry
cpaulsen
Oregon
Posted: 11/22/20 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Ended up being a bad switch for the awning.........a new switch and everything works great!
 > awning
