joe blow
ca
Hi,
I have a slightly leaking black water tank valve as of late and have been considering replacing both valves and all the black piping complete. After looking at the plumbing it seems to be a nightmare and can of worms to replace the piping new.
It appears the valves are rebuildable and/or serviceable by unbolting the 4 1/4" bolts swapping out the old, slipping in the new.
Is this the case?
Thanks for the advice
Joe
william_04_x
LV,NV
Replumbing the exterior dump lines isn't bad as long as the tank connections are solid. You'll pretty much duplicate what's there with new pieces. If it's not leaking, no need to replace it.
The dump valves are that simple. Get replacement valves with metal handles.
05 WW FS2600
Dragging around Can Am and Polaris junk
joe blow
ca
Excellent. I initially was considering doing the plumbing which seems pretty straight forward, but in some spots it might turn into a nightmare.
opnspaces
San Diego Ca
Yes it's that simple. You will need to unbolt the 4 bolts at the valve and whatever hangers are downstream from the valve. This will allow you to flex it enough to slide the old valve out and the new valve in.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
joe blow
ca
Thank you all for the help and advice
nayther
Burbank, CA
Do it before the valves fail, had one break once, pulled the handle out of the disk. Of course it was a black water tank that was FULL!
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Huntindog
Phoenix AZ
nayther wrote: Do it before the valves fail, had one break once, pulled the handle out of the disk. Of course it was a black water tank that was FULL! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif) ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
last
edited 01/02/21 05:49pm by Huntindog *
View edit history
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
Full Body Paint, 3, 8K axles, Disc Brakes
17.5 LRH commercial tires
540 watts solar,
2020 Silverado High Country CC DA 4X4 Big Dually.
nayther
Burbank, CA
Huntindog wrote: nayther wrote: Do it before the valves fail, had one break once, pulled the handle out of the disk. Of course it was a black water tank that was FULL! That was a bad situation
got lucky and found a dump station that I could back over, one with a catch basin around it (this was a truck camper so valve was in far back corner. Unbolted the bolts very carefully and got the **** to drain enough to make it work but it was still a NASTY job.
