RV.Net Open Roads Forum: Tech Issues: 2 Years Without Changing Oil?
 > 2 Years Without Changing Oil?
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 11/17/20 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
95 that passes smog only gets driven 50 miles a month. The trips and environment warm up the oil on the dipstick beyond 120°F
BurbMan
Islip, Long Island
Posted: 11/17/20 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
Yes but condensation forms as temps drop in the overnights...why vehicle mfrs also specify a time interval and a mileage interval "whichever comes first".
Also assuming vehicle gets started more than 1x per month, the engine doesn't get enough heat cycles to burn off contaminants.
Unless you're talking about a lawnmower you're accelerating engine wear unnecessarily
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Sjm9911
New Jersey
Posted: 11/17/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a jeep as a fun vehical, i have gone a year but not over changing the oil. Not much money to do it. I did have the calibers lock up from non use. Thats was $$$.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
time2roll
I would go at least two years. At 600 miles a year and always put away hot I may never change the oil again.
675w Solar pictures back up
jjrbus
FT Myers FL
Posted: 11/17/20 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
I come from an industry that tests the oil and only replaces it when it becomes contaminated. So I do not get real excited about intervals.
fj12ryder
Platte City, MO
Posted: 11/17/20 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
At 600 miles per year, who cares if you only get 20,000 miles out of the engine? That's over 30 years, so yeah, I'd change it no more than every couple years, maybe longer.
Howard and Peggy
"Don't Panic"
pnichols
The Other California
Posted: 11/17/20 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
Especially with synthetics ... I change the Mobil 1 in my motors (vehicles plus generators) only when it looks too dark colored. IMHO, "fresh oil" is far less important than unbroken down oil that still appears relatively clean/clear.
I once had an uncle that - with his first brand new car (a Ford) - drove it at least 90,000 miles before he changed it's oil. The oil as black as pitch when he had it changed but it still ran like a top.
Kindof related to oil changes ... our motorhome has over 81,000 miles on it and it's still on it's good original front and rear brake pads.
Phil, 2005 E450 Itasca Spirit 24V
Wherever I happen to park
Posted: 11/18/20 12:21am Link  |  Quote  |  Print  |  Notify Moderator
Gas or Diesel?
The reason I ask if that Gas engines oil changes tend to be around 65 dollars at most of the shops I visit
Diesels 100 and up
There are labs. You drop a drop or 2 of oil from the dipstick onto or into what they send you and mail it back and they tell you if it's time to change. Never used one so don't know the price (gas engines)
Home is where I park it.
Gjac
Milford, CT
Posted: 11/18/20 05:42am Link  |  Quote  |  Print  |  Notify Moderator
I went several years before changing my genset oil because I only put 10 or 12 hrs a year on it. The dipstick was always clean and the level was good. When I did change it there was a lot of white creamy sludge in the bottom that did not show up on the dip stick. So condensation is a real problem especially over the winter, and even though I ran the genset before I drained the oil it did not burn off all that sludge. I don't know what an oil analyses would cost but I am sure it is more than my oil change and filter. I am sure there are a lot of variables as to were you live how long the engine sits between use etc, but I think a yearly oil change or every 12,000 miles is good advice.
JaxDad
Greater Toronto Area
Posted: 11/18/20 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Hang on a minute, let’s put this. In perspective.
MEXICOWANDERER wrote:
..... only gets driven 50 miles a month.
50 miles a month is 600 miles a YEAR.
Accelerated wear? At 600 miles a year? So then the engine will wear out in just 40 years instead of 60 years?
