RV.Net Open Roads Forum: Tech Issues: freon charge in a Dometic
 > freon charge in a Dometic
garysol
Kalamazoo Michigan
Posted: 11/18/20 06:41am Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone. Is there anyway to verify low freon charge in a Dometic 15,000btu without installing a line tap and ambient air temperature is to cold to really check output temperature? Compressor load test maybe?
2020 RAM 3500 HO
2018 Kodiak Ultimate 288BHSL
2017 Ram 2500 6.4 (SOLD)
2016 Heritage Glen 263RL (sold)
2012 Komfort 3530 (sold)
2008 Keystone Sprinter (DOA)
014 Ram 3500 6.7 (sold)
Bill.Satellite
Full-timer
Posted: 11/18/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I don't believe there is any such option as they are all sealed units.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
dougrainer
Carrolton, Texas
Posted: 11/18/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
You take a TEMP compensated AMP draw of the compressor. VERY accurate. There is a Compressor AMP draw stated on the AC model label. THAT amp draw is based on 95 degree ambient temp. So, you subtract 1 AMP for every 10 degrees below 95 degrees. ADD 1 AMP for every 10 degrees above 95. Lets say the Rating is 12.2 amps for the compressor. It is 75 degrees outside. Subtract 2 amps. The Compressor after running a minimum of 15 minutes will draw 10.2 amps. IF lower, by more than 1 amp, you have lost part of the charge. IF 80 degrees subtract 1.5 amp, same test. Doug
garysol
Kalamazoo Michigan
Posted: 11/18/20 11:54am Link  |  Quote  |  Print  |  Notify Moderator
Thank You Doug! I had never known that. I learned something new today.
dougrainer
Carrolton, Texas
Posted: 11/18/20 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a low charge, it MUST have a leak. I have never seen a Low charged RV unit in 41 years as an RV tech, that did not have a leak. They only hold about 1 lb of coolant. So any leak will cause a drastic reduction of cooling. Doug
Wherever I happen to park
Posted: 11/18/20 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
You use the old 4 point thermometer and ammeter to do it
Inlet and outlet temps both inside and out
Humidity
And compressor amperage
And then there should be a book that tells you what you need to know.
The problem is the books are specific to the make and model and I have no clue where to find it. outside temps should be over freezing. help if over 40
Home is where I park it.
MrWizard
Traveling
Posted: 11/19/20 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
I think what you are referring to, is/was for commercial systems, and very likely that no such books are published pertaining to RV units
Can't read what's never been printed
Radiate The Happy
1997 F53 Bounder 36s
red31
Dallas
Posted: 11/20/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
I use info published by a different a/c maker.
https://www.airxcel.com/docs/default-sou........ting_ac_performance.pdf?sfvrsn=8f50e6b_5
dougrainer
Carrolton, Texas
Posted: 11/20/20 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
The chart is WRONG. If you use RVP's 5 degrees instead of the correct 10 degrees, EVERY RVP unit will show BAD. I went thru this with RVP 3 years ago at the last training school. Doug
