RV.Net Open Roads Forum: Travel Trailers: Propane furnace issue
 > Propane furnace issue
BurbMan
Islip, Long Island
Posted: 11/18/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
Again what makes you think that the furnace shutdown is gas related? It could be a moisture problem but there are other possible causes also.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
rmauk
Pennsylvania
Posted: 11/18/20 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
The furnace is a Suburban and the regulator is a Fairview two stage. There is a black dial on the regulator. It screws in and out.
enblethen
Moses Lake, WA
Posted: 11/18/20 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
You should not be turning the black knob without using a manometer to properly adjust it.
Fairview two stage regulator
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
rmauk
Pennsylvania
Posted: 11/18/20 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Oh.
deltabravo
Spokane, WA
Posted: 11/18/20 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hyperlinking to a file on your C drive does not work.
Your link goes here:
C:/Users/enble_000/Downloads/YY-INSTRUCT-GR-9950P%20%20GR-9959P%20and%20GR-9954P%20X-SERIES%20FAIRVIEW%20LTD-2019.pdf
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20, sold 7/28/20)
enblethen
Moses Lake, WA
Posted: 11/18/20 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
Here is main page. You have to go to "installation" to get to my previous attempt.
Fairview regulators
eHoefler
ozark mountains
Posted: 11/19/20 06:10am Link  |  Quote  |  Print  |  Notify Moderator
2 things
The tare ( empty ) weight of a 20# propane tank is 17#, if you tank weighs 12#, its empty and you scale is way off.
2nd, at that outside temperature, your propane may not be able to vaporize to meet demand of the furnace. Try warming the tank with a heating pad. They make a propane tank heat that attaches to the bottle.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
rmauk
Pennsylvania
Posted: 11/19/20 06:32am Link  |  Quote  |  Print  |  Notify Moderator
My tank weighed 28+ lbs. I weighed an empty tank at 17- lbs and deducted I had 12# propane remaining. I understand propane is problematic at low temps, I am just surprised that I am having problems just below freezing.
midnightsadie
ohio
Posted: 11/19/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
might be you moving the black knob,,
time2roll
Posted: 11/19/20 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Could have some butane in the cylinder. If you have a heating pad put it on the cylinder to burn it off. Otherwise exchange the cylinder.
675w Solar pictures back up
