RV.Net Open Roads Forum: Class A Motorhomes: Power gear levelers
 > Power gear levelers
Bigsteve909
Hesperia
Posted: 11/18/20 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone, I have a 2007 fleetwood excursion 40e my levelers are up and I can’t get the jacks down light to turn or stop making noise. I’ve done all the troubleshooting suggested and still not working. I’m wondering if anyone on here has experienced same thing. Thank you in advance.
I can manually jump from outside control panel but no response as from inside house panel.
howdy35
Athens, Texas
Posted: 11/21/20 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Find your Jack reservoir and check to see if the fluid level is low. Low fluid level can give you the kind of problem you are posting.
Happy travels. Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
Belgique
Hickory, NC
Posted: 11/21/20 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Electric jacks right? Power Gear has a lot of trouble shooting guides on their site that might help. Your problem is one that I haven't had....yet. Good luck.
Hickory, NC
2007 Fleetwood Discovery 40X
Waiter21
NW Ohio
Posted: 11/26/20 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
If theses are Power Gear hydraulic, they use the hydraulic level in the reservoir to detect if the jacks are retracted. If the level is a little low, it thinks the jacks are still down.
With the jacks fully retracted, top off the reservoir with fluid. This is how I did it on mine.
https://www.1999southwind.com/flush-and-refill-leveler-hydraulic-system/
1999 Southwind F53, 2003 Saturn Vue toad
www.1999Southwind.comwww.1999Southwind.com
