specta
utah
valhalla360 wrote: to keep rust at bay.
Pun intended?? LOL
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
jaycocreek
Idaho
Not knowing what to expect,I cleaned up and painted my horizontal tanks so they would be ready for recertifying..The propane guy looked them over and put a new certification on them..Mine are pre-1998(if that's the year) and fell into the grandpa clause..I had it in the back of my mind I would have to get new tanks but luckily I did not.
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
specta
utah
jaycocreek wrote: I had it in the back of my mind I would have to get new tanks but luckily I did not.
No kidding, 30 lb horizontal on eBay - $202.59 shipped.
NRALIFR
Truck Camping Out West
specta wrote:
They fill them in the vertical position.
Now that you ask, I wonder if that's right way to fill them. ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
I would think yours would have a label, or possibly stamped in the top ring what the filling orientation is. The relief screw could have its own dip tube that is intended to show an 80% fill when the cylinder is vertical.
![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
2001 Lance 1121 on a 2016 F450
specta
utah
I went back out and looked and you are 100% correct.
jaycocreek
Idaho
That's funny because my propane guy(The manager) wasn't sure and he looked on the tank also..LOL
Kayteg1
California > Nevada
NRALIFR wrote: I took the cylinder to the local Ferrellgas dealer, and they came to the same conclusion: Bad valve.
The valves are pretty complex mechanism and 1 of the part is push-valve, who needs correct hose fitting for it to open.
I found it several times already that not all new hoses have well build fitting and it will not open the valve on tank.
Replacing the hose fitting solved the issue.
My horizontal tanks have clear label to be filled in vertical position.
The gauge works in both positions, although it is more precise in horizontal.
NRALIFR
The push-valve part is definitely working. The first thing I tried was just swapping the two pigtails between cylinders. No matter what I did, the one with the bad valve just wouldn’t work. I even tried my Webber grill using it’s pigtail, with no luck.
I could tell that the guy at Ferrellgas had removed the valve to examine it, but when it was reinstalled it still wouldn’t work. No clue what it’s problem could be.
Kayteg1
California > Nevada
We are living in disposable society, where it is easier to replace whole assemble, than find qualified technician to do actual repair.
We don't replace $5 alternator brushes, but do $500 alternator replacement.
The poppet valve in the main valve is not a rocked science and I found a site where you can buy the parts, but good luck finding service station who would stock them and have qualification to replace them.
When I had the issue, I simply found old hose fitting in my garage - the one with male thread and put it on. Problem never come back.
noteven
Turtle Island
Propane fittings are kinda like hydraulics and fire apparatus connections - how many ways and styles can you invent to move liquid under pressure from point a to point b...
