RV.Net Open Roads Forum: Tow Vehicles: Ram 2500 DEF fluid
Search only in Tow Vehicles
 > Ram 2500 DEF fluid
Page of 5
RamRider
Central Texas
Posted: 11/19/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
I usually top up my DEF at around 6000 miles or when it shows 1/2 full. Use of DEF is proportional to fuel use, thus when towing you will use more fuel and more DEF but even so you are not using much DEF
happy travels
2014 Airstream 25FB
2016 Ram
Blue Ox Sway Pro
ARE Topper
ShinerBock
SATX
Posted: 11/19/20 10:01am Link  |  Quote  |  Print  |  Notify Moderator
The DEF usage ratio is about 50 to 1 per Cummins meaning for every 50 gallons of diesel fuel burned, you will use 1 gallon of DEF. The less miles per gallon you get in fuel, the less miles per gallon you get in DEF. So if you are getting 15 mpg, then you are getting 750 mpg in DEF. If you are getting 10 mpg, then you are getting 500 mpg in DEF. Basically, multiply 50 times your MPG and you will get your DEF mpg.
ACZL
UPstate,NY
Posted: 11/19/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
As already stated, it varies a lot (towing VS not towing), but in general, you will only fill the DEF 1-2x/yr.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
markandkim
Swansea, MA.
Posted: 11/19/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Bionic Man wrote:
In theory, you should need DEF about the same time you need an oil change. But there are a LOT of variables to that.
Your DEF gauge is probably working just fine. You shouldn't need to fill after 6 tanks of fuel. According to Cummins, DEF consumption is 3% - 5% of your total fuel consumption.
The DEF tank on a 2016 2500 is 5.5 gallons.
It won't last 15000 miles. That is when the oil change is due.
1/2 of a tank of DEF goes about 3000 miles.
Retired Navy
2020 Ram 2500 Bighorn 6.7L
2014 Crossroads Zinger 27RL
mudfuel07
North Florida!
Posted: 11/19/20 11:15am Link  |  Quote  |  Print  |  Notify Moderator
When I had to use it on mine, I think I was putting in a jug every couple of months, maybe every 5-6 tanks. It really burns through it when towing, I felt like I could see the gauge move.
2017 Ram 2500 6.7 CTD 4x4 SLT
2020 Puma by Palomino 32RBFQ for the kids!
trail-explorer
NM
Posted: 11/19/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
samhain7 wrote:
Hi all
I am on tank of gas # 6 on my new to me truck and thrnDEF fluid gage has barely even moved
Why does a gas powered truck have a DEF gauge?
Bob
wanderingbob
monticeeo, fla
Posted: 11/19/20 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
On my 2500 CTD , when gauge sez 1/2 I pour in 2 1/2 gallons . But you are correct , it will say full and then " bang " , it is on half !
BurbMan
Islip, Long Island
Posted: 11/19/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
My DEF gauge sat at F all summer, then we took 1000 mile road trip to PA with the camper and I used 1/2 tank of DEF. This is my first diesel truck and one thing I found out is that DEF has an expiration date, and stale DEF can clog up expensive parts.
I took the camper out one more time and DEF is at 3/8...but camper is winterized and it might stay at 3/8 till next year, so I'm not in a hurry to go out and buy more just yet.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Learjet
Louisiana
Posted: 11/19/20 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
this video will answer and show you how the DEF gauge works
https://youtu.be/czJZuc8ThhI
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
samhain7
Toronto
Posted: 11/19/20 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
samhain7 wrote:
Lynnmor wrote:
Your gas truck will run forever without filling the DEF tank. [emoticon]
The answer to your question is in the owners manual.
Gee, thanks for the help
[emoticon]
You're welcome.
I just thought that I didn't want to sit and type up everything that you already have in your possession. [emoticon]
Then don't answer. Like at all
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
Page of 5
