RV.Net Open Roads Forum: Class A Motorhomes: Draining hot water tank
 > Draining hot water tank
ezgoin
Sunny Arizona
Posted: 11/19/20 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Hi everyone,
Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem.
Thanks,
Bill
The older I get....the better I was.
Bill & Terry
And our canine kids, Skippy & Peanut
2014 Fleetwood Bounder Classic 30T
2016 Jeep Wrangler Unlimited Toad
TenOC
On the road -- Full time
Posted: 11/19/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
You don't drain your hot water heater at home when you leave for a few weeks or month do you? The same goes for your RV hot water heater. Oh by the way it's a cold water heater. It probably is best to not drain it because if it's full and oxygen will not get in and cause parts to rust.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
midnightsadie
ohio
Posted: 11/19/20 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
my rv is a 2007 drain the tanks every trip and the hot tank. if not that tank of hot water could smell really bad. p.s 2007 and the hot tank is org.
schlep1967
Harrisburg, PA
Posted: 11/19/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
If several months, yes I would drain it.
Especially if it wasn't filled from a water source I know. If it was filled from my well, I know there is not a Sulphur issue. Others, it can stink something terrible when you heat it up and run it into the camper.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
wopachop
Who run bartertown
Posted: 11/19/20 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Is it brand new?
dougrainer
Carrolton, Texas
Posted: 11/19/20 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
You drain to keep the water and inner tank lining from getting the dreadful sulpher(rotting egg) smell. Doug
wallynm
Los Alamos NM
Posted: 11/19/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
We drained it every fall when we winterized.
ezgoin wrote:
Hi everyone,
Thanks,
Bill
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
wildtoad
Blythewood, SC
Posted: 11/19/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I do know that Suburban states to drain the water heater when not going to be used for a while.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 11/19/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I flushed mine several times and used vinegar on it when I bought it. I use a three filter system on it and have only drained it twice in the last seven years and that was when I winterized it while up north.
As stated above, when was last time you drained your home water heater?
If you're winterizing it, once a year is more than enough,
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Branson N Tucson
Tn
Posted: 11/19/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I Drain my water heater at least twice a year.
This is due to the hard water and calcium build up.we spend our winters out here in Arizona.
You wouldn't believe the white chunks that come out. We also have a soft water heater in use.
