RV.Net Open Roads Forum: Dinghy Towing: Surge breaks on a dolly
Search only in Dinghy Towing
 > Surge breaks on a dolly
Bumpyroad
Virginia
Posted: 11/20/20 05:36am Link  |  Quote  |  Print  |  Notify Moderator
ferndaleflyer wrote:
Don’t want to discourage anyone from getting brakes but I have used a dolly without brakes for as long as I can remember with zero problems. I have hauled everything from an Excursion to my current Smart car. A DP like I have can stop it if it’s set up correctly.
I'm sure there are hundreds/thousands out there with the same story. doesn't affect my decision one iota.
bumpy
BarneyS
S.E. Lower Michigan
Posted: 11/20/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
The OP said he was going to use a two wheel dolly. Don't see why there would be any tire scrub with a two wheel dolly when turning.
Moved to Dinghy Towing forum from Towing.
Barney
Not towing now.
JRscooby
Indepmo
Posted: 11/20/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Barney
If the wheels on dolly don't turn, or some other system in place so the wheelbase dolly/back axle can not change side to side, tires on back of car, or dolly will need to slide sideways to make a turn.
Bedlam
PNW
Posted: 11/20/20 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Agreed: If the dolly has fixed platform AND the vehicle attached to it has the steering locked, you will get scrub when making turns due to the different tracks of each axle.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
BarneyS
S.E. Lower Michigan
Posted: 11/20/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
I get it now. Thanks! Wasn't thinking straight this morning.
Also forgot to move it. Moving now.[emoticon]
Barney
Campinghoss@51
Windsor NC
Posted: 11/20/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
When I had my dp motorhome I pulled an ACME dolly with surge brakes. You had to leave the steering wheel unlocked to keep from scrubbing the tires. I ran it about 10000 miles before I went to a four down car. I never had any issues with the dolly tires or anything like that. I think the ACME use inverted steering to avoid the scrub. If I was to go back to any type of dolly now, it would me an ACME.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
rjstractor
Maple Valley, WA
Posted: 11/20/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Class A motorhomes come in a vast range of weights and braking abilities. A small 12000 lb motorhome towing 4000 lbs of unbraked load will take a lot longer to stop. On a 50000 lb tandem axle motorhome, the weight difference and the stopping distance difference will be much less. It's never a bad idea to have brakes on the towed load, but it becomes a much better idea as the weight differential increases.
JRscooby
Indepmo
Posted: 12/06/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Brakes on any vehicle are designed to stop the GVWR, with a margin for safety. If the 50,000 lb MH in your example has a GVWR of 52,000 lbs, and you hang a 4,000 lbs un-braked on the back you are 2000 lbs into that safety margin. You would not want your kid in front of that rig. Why would you want to put somebodies else's kids there?
Bumpyroad
Virginia
Posted: 12/06/20 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I am curious if there are any folks who will play the weight rating game, GVWR, etc. to avoid spending a few bucks on dolly brakes a true safety factor, and then in another thread spend funds to change clearance lights to LEDs which affect nothing, and stop lights which will cut a few seconds off of light activation time.
bumpy
Posted: 12/07/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Your A’s brakes aren’t designed for an extra 4 to 5000 pounds.
Clairvoyant today?
