RV.Net Open Roads Forum: Class A motorhomes with a Ford V10 Chassis
 > Class A motorhomes with a Ford V10 Chassis
blazenpm
Home
Posted: 11/19/20 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
I am curious if there is a prevalence of Ford V10 engines with issues. For instance: throwing a cylinder rod and puncturing the engine casing. Starter motor failing and needing to be replaced.
wolfe10
Posted: 11/19/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
In a word, NO. One of the more reliable gasoline engines ever used in an RV.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
PastorCharlie
NC
Posted: 11/19/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
NO.
Lone Pine, CA
Posted: 11/19/20 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
That engine has a good reputation
haste maker
alabama
Posted: 11/19/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
No..have you had this problem? Or has a dealer selling another brand told you this?
Retried Teamster
2007 Allergo
pianotuna
Regina, SK, Canada
Posted: 11/19/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing since the spark plug issue. Bullet proof is one description.
Regards, Don
carringb
Corvallis, OR
Posted: 11/19/20 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Just to be clear, you need a new starter... But you aren't sure if you want to replace it because you fear a rod going through the block? I've never seen that. In fact, it was rare I ever had a V10 get towed in to the shop.
I know one up-fitter that hit a deer a Wyoming, and drove it (a F250 V10) 1,000 miles back to headquarters in Oregon without coolant. I've driven 300+ miles without an intact radiator myself, and another time without a working alternator. The only I've been stranded and required a tow home, was when I sheared my differential pinion gear in half (don't turn off torque management for the 1-2 shift!)
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Lone Pine, CA
Posted: 11/19/20 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Unanimous!
camper19709
middletown,DE
Posted: 11/19/20 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
No.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
Bruce Brown
Northern NY
Posted: 11/20/20 04:15am Link  |  Quote  |  Print  |  Notify Moderator
This.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
