RV.Net Open Roads Forum: Class A motorhomes with a Ford V10 Chassis
 > Class A motorhomes with a Ford V10 Chassis
JoeH
Apollo Beach,FL
Posted: 11/20/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
I had a 1999 V-10 in 36' Pace Arrow Vision. So it was pretty heavy and I pulled either a toad or a 20ft enclosed trailer. 150,000 miles with only 2 minor issues--- idler pulley bearing for serpentine belt went bad at about 10k miles and the starter relay died at about 15k miles. Both covered under warranty and easy fixes. Great trouble free engine
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
dodge guy
Bartlett IL
Posted: 11/20/20 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Never an issue. Only problem on early ines were plugs spitting and exhaust manifold bolts breaking. Other than that it is one of he few engines that won't leave you stranded.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
carringb
Corvallis, OR
Posted: 11/20/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
JoeH wrote:
I had a 1999 V-10
OP, it you're still there... This is a good point.... The starters on the V10 rarely fail, but the starter relays DO fail. I usually need a new one every 100k or so, so I carry spare now.
2014 ORV really big trailer
2015 Ford Focus ST
crawford
Dandridge Tenn.
Posted: 11/20/20 11:40am Link  |  Quote  |  Print  |  Notify Moderator
More fake news going on LOL
Change from a c class to a A class Georgetown 07 triple slide
DrewE
Vermont
Posted: 11/26/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the others--it's pretty much a bulletproof engine if given basic maintenance. That isn't to say that accessories (including the starter) won't eventually wear out, but that's true of any engine; but the V10 is overall quite reliable and robust.
Waiter21
NW Ohio
Posted: 11/26/20 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
V10 has been a good motor, but like any mechanical device, some have their peculiarities. These are rare events, but seem to be peculiar to certain vintage V10s:
1999-2003ish - blowing spark plugs. seems to be torque related, as in not enough. plug loosens up, then vibrates around and destroys the threads and the plugs blows out.
2003ish 2006ish - two park spark plus break when attempting to remove.
2016 lifters / rockers destroyed.. May be an issue with oil pressure. When engine was assembled inadequate sealant around tension-er allows oil to leak, reduced oil to lifters/rockers.
Starters - Ford has always had issues with starters. Heat from the exhaust system seems to contribute to the failures. I install a heat shield on my starter to reduce the heat from the exhaust system.
Exhaust manifold studs have always been an issue with all Ford modular engines. Thankfully, motorhome V10s are a lot easier to repair than the pickups and vans.
https://www.1999southwind.com/f53-replacing-broken-exhaust-manifold-studs/
1999 Southwind F53, 2003 Saturn Vue toad
www.1999Southwind.comwww.1999Southwind.com
howdy35
Athens, Texas
Posted: 12/06/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Back in 2002 we were traveling in a 1999 Bounder and for three years drove it from Texas to Florida to Alaska and all over the western Rockies while pulling toad. She huffed and puffed and screamed up every mountain but I never had any problem with the engine. I did change the oil to Amsoil right after I bought it and was quite happy with the V10.
If someone is feeding you a line about the suspected reliability of the engine, I wouldn't buy it.
Happy travels, Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
ernie1
Sacramento,California,USA
Posted: 12/06/20 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2005 class b mh with the v10 engine and drove it for 13 years and 89,000 miles and never had any problem with it. It hardly ever used any oil even though I ran it hard and I am still amazed at what I read in the owner's manual that stated that if the engine happened to have a coolant leak and it ran out of coolant, you can still drive it about another 50 miles without damaging the engine. The engine, when out of coolant, will continue running on only a few cylinders and not all ten. I never tried it but always felt assured that I wouldn't be stranded because of this. Also never lost any spark plugs, cracked any exhaust manifolds nor had starter nor relay problems.
Newps
Seeley Lake, MT
Posted: 12/07/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
50 miles may be theoretically possible but practically speaking you aren't going any distance. I have had 3 V10's in my F250's. My current one is my plow truck, a 2007. On a trip to town the engine light came on at the same time it slowed to a crawl. I was on the highway doing 70-75 when a heater hose coupling let go. As the coolant got to that spot it leaked out. Engine temp climbs right to the red and you are in limp home mode. You can get maybe 10-15 MPH. You won't be climbing any hill. At this point find a safe place to pull over.
ernie1
Posted: 12/07/20 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Newps: thanks for clarifying this.
