RV.Net Open Roads Forum: Can you buy new what CA rents
 > Can you buy new what CA rents
CharlesinGA
South of Atlanta, Georgia
Posted: 11/21/20 11:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yes they do keep it simple, No awning, no electric steps, no shades with strings, none of that fragile stuff that RV companies use. The CA units have a step box built in so they don't need the electric steps, they use regular cloth curtains, no awning to leave out and tear off or improperly stow. Its that kind of stuff that makes them a solid rental vehicle. I think they all have the 5.4 V8 and not the V10 also.
Charles
Gjac
Milford, CT
Posted: 11/24/20 06:48am Link  |  Quote  |  Print  |  Notify Moderator
Charles
I did not know the engines were different, I assumed they they had the same chassis in the rental units that they sold to you and me. Do you think the 5.4 V8 is more reliable than the V-10?
carringb
Corvallis, OR
Posted: 11/24/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
All E450s have the V10.
The short units such as the 19G, built on the E350 chassis, had the 5.4L.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
IAMICHABOD
Sunny So Cal 90713
Posted: 11/24/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
The Majestic 19G and the 23A built on the E350 Chassis with the 5.4L. V8.
The Majestic 28A built on the E450 Chassis have the 6.8 liter V10.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
IAMICHABOD
Sunny So Cal 90713
Posted: 11/24/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
rjstractor
Maple Valley, WA
Posted: 11/24/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
If I'm not mistaken the 6.8 V10 is literally a 5.4 with a longer crank and block to accommodate two more cylinders. If you do the math the cylinder sizes are exactly the same. I suppose the 5.4 might be incrementally more reliable with fewer moving parts, but both are very reliable engines.
DrewE
Vermont
Posted: 11/26/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Yes, they're both examples of the Ford modular engine family, sharing the same cylinder spacing, bank angle, and other key block dimensions. There are some other differences between the V8 and V10, though, such as the addition of a balance shaft to the V10 (as required to keep vibration under control). Both are quite reliable engines.
I sometimes wish Ford had made an 8.1L V12 engine as part of the line; that should make for a very smooth running and decently powerful engine.
