RV.Net Open Roads Forum: Truck Campers: New thermostat question?
 > New thermostat question?
Page of 5
notsobigjoe
southeast
Posted: 11/19/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
My Lance 1181 came with a Atwood hydro flame 38535 dual stage thermostat and I see that is is no longer available. I have looked but I am not a digital kind of guy. I simply don't know what to get. Would this model work?
Coleman 8330-3862 83303862 Digital Thermostat
can be found here,
https://colemanmachac.com/coleman-mach-wall-thermostat-8330-3862/
* This post was edited 11/19/20 04:11pm by notsobigjoe *
enblethen
Moses Lake, WA
Posted: 11/19/20 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
I changed mine out to one of these. Lux
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
notsobigjoe
southeast
Posted: 11/19/20 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
I can use a home model in an RV? Isn't mine 12 volt? Like I said, no clue...
Thanks, Joe
enblethen
Moses Lake, WA
Posted: 11/19/20 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, any low voltage thermostat.
I just have to remember to change batteries.
towpro
Compass PA
Posted: 11/19/20 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
the digital display home type will run off batteries inside the thermostat. Just keep some spares with you. I think I would get a year out of a set.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
notsobigjoe
southeast
Posted: 11/20/20 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Thanks very much. That gives many more options.
jimh425
Western MT
Posted: 11/20/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that unless you put exactly the same type as someone else with the same setup, and follow their instructions, there may be some trial/error to figure out which wires do what. Of course, if you can replace with the same brand, it’s also probably going to be easier.
Not that hard, but just a heads up.
I went with a digital that has a huge display and light. Then, I can adjust the heat at high in the dark without putting on reading glasses.
mbloof
Beaverton, OR
Posted: 11/20/20 06:45am Link  |  Quote  |  Print  |  Notify Moderator
The thermostat on most RV furnaces is a simple two wire interface.
Just about any 2-wire thermostat will work as a replacement of the stock unit.
- Mark0.
enblethen
Moses Lake, WA
Posted: 11/20/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Your old thermostat should have identification as to the wire terminals. Take photo. The new thermostat should have tape style markers for wires. Mark the wires as to the function location from old thermostat.
OP says he has a dual stage thermostat.
okanstar
placerville
Posted: 11/20/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Make sure it can be turned off , or to another mode like ac . Or the fan will run if the temp falls below the lowest temp setting .Or at least disconnect battery's when not used .
Page of 5
