RV.Net Open Roads Forum: Help! Onan 4K generator refuses to start and stay on
 > Help! Onan 4K generator refuses to start and stay on
Kennyg
Green bay, Wi 54303
Posted: 11/19/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Pulled RV out of 6 month storage. Attempted to start generator. Will start, but quit after about 6 seconds. Repeated attempts with no success.
When it does start, it runs only briefly. It seems to me that it is not getting a constant flow of gas. Should I empty the "float bowl" to get clean gas ( no I didn't drain the bowl before placing unit into storage) and then attempt to start again.
The fault light indicates a fault 36. This fault seems to imply I should either clean or replace the spark plug.
Any and all advise will be greatly appreciated
Kennyg
Stim
NE Florida
Posted: 11/19/20 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have MORE than a 1/4 tank of gas?
jdc1
Rescue, Ca
Posted: 11/19/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Time to clean the carb.....
Kennyg
Green bay, Wi 54303
Posted: 11/19/20 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
Yes
Kennyg
Green bay, Wi 54303
Posted: 11/19/20 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Carb is only 2yrs old. Do you mean removing and cleaning??
Home Skillet
Pearland Texas
Posted: 11/19/20 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
I gave up on cleaning the carbs. There are small passages that are capped off, which makes them hard to clean.
Treat your fuel with Startron before storing. Or, drain the carb.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
rockylarson
Jersey Shore
Posted: 11/20/20 04:09am Link  |  Quote  |  Print  |  Notify Moderator
What worked for me is to start it up with no loads, zero, and let it warm up before adding devices.
Refrig, converter, water heater, air conditioner, space heaters, and any other 120 volt devices you may have, Microwave, tv's.
I also never park for more than a couple weeks without gas stabilizer in the tank.
Fault 36 is a catch all with fuel related at the top but electrical issues not far behind
Good Luck
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
bobndot
Posted: 11/20/20 04:44am Link  |  Quote  |  Print  |  Notify Moderator
Untreated gasoline. You probably did not use a reputable fuel stabilizer in the gas tank then run that mixture through the genny, so that stabilized fuel sits in the carb and fuel line.
Remove the carb bowl and wipe it clean. You can use Sea Foam, StarTron or Marine Stabil in the gas tank. They have all worked equally as well for me.
There is also a fuel filter which needs to be changed every 450-500 hrs of run time. YouTube shows you how to do both.
2naEagle
McCalla, AL
Posted: 11/20/20 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Found this video. I haven't done this but looks like it would work.
Can & Hose Method
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Redhawk 24B
Gjac
Milford, CT
Posted: 11/20/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
Can & Hose Method
This is what I do when ever I have a problem starting or keeping the genset running. It also shows you if the problem is a loose hose clamp or a cracked fuel line to the main tank drawing air in instead of enough fuel to keep it running. With the other half of the Seafoam I put it into the crankcase before I drain the oil. You would be surprised at the carbon that comes out of the sump if you never did this before. It also shows you how much fuel you burn in an Hr under load.
