RV.Net Open Roads Forum: Class A Motorhomes: Atwood 8535 heater
 > Atwood 8535 heater
prento
england
Posted: 11/20/20 06:28am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,Attwood 8535-iv dclp heater problem on my rv,the heater will start up(fan going)but is having trouble lighting the furness sometimes it lights then it cuts out and stops,if you look at the circuit board outside next to the heater there is a red warning light on the circuit board that flashes 3 times off and on,any ideas what the problem is.
wanderingaimlessly
SOBOVA
Posted: 11/20/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Maybe a search online for a troubleshooting guide, or this overall atwood guide which includes other appliances Atwood
Also a check on you tube will give quite a bit of info on troubleshooting those units.
Good luck.
enblethen
Moses Lake, WA
Posted: 11/20/20 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Clean the contacts on the circuit board with a white pencil eraser
Clean the electrode/flame sensor. make sure it is adjusted correctly.
Clean the burner area.
If running off battery, insure it is charged
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
2oldman
NM
Posted: 11/20/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Your Betty Furness may be on its way out.
Old-Biscuit
Verde Valley
Posted: 11/20/20 10:27am Link  |  Quote  |  Print  |  Notify Moderator
RED LED Flashing 3X....Ignition Lockout Error Code
Circuit board WET?
Dry it using Hair Dryer...then try again
If it works you might want to consider a Relocation Kit
(Atwood KIT includes a NEW circuit Board WITH a plastic Bracket that lifts circuit board up....make your own bracket)
Relocation Kit...circuit board is generi........rnaces/7900 thru 8900 AFS, AFM, AFL, etc
If not WET....circuit board is at fault
Dinosaur Electronics Fan50Plus Circuit board for replacement
Better quality circuit board
Dino Fan50Plus
US NAVY------USS Decatur DDG31
Bird Freak
Dallas Ga.
Posted: 11/20/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Mine did the same thing.
Circuit board. Replace it with a Dinosaur. Much better than OEM.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
