RV.Net Open Roads Forum: Truck Campers: Winterization of hot water heater?
 > Winterization of hot water heater?
joe&julie81
Cleveland, TN
Posted: 11/20/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
After draining all the water from the tc,including removing the plug from the hot water heater, what else? The anode attached to the plug is half eroded away, I guess it should be replaced? Should the plug be left out so the inside of the tank might dry out. Should I blast warm air in there to try and dry it out? I'm trying to prevent premature electrolysis from pitting the aluminum. Any thoughts?
04 Dodge 3500 dually, HO CTD, 6 spd NV5600, 4.10 anti-spin rear axle; 2018 NorthStar 950sc with 320 solar, sub-zero package, compressor fridge, torklift tie downs
deltabravo
Spokane, WA
Posted: 11/20/20 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing else needed. I leave my anode rod out for a while so the remaining water evaporates.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Sjm9911
New Jersey
Posted: 11/20/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
I cover mine so bugs and stuff cant get in it. Make sure its bypassed, and some rinse them out to get the gunk out of them.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Death Valley NP
Posted: 11/20/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
I’m a “rinser” as Sjm mentioned.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
rockylarson
Jersey Shore
Posted: 11/21/20 03:45am Link  |  Quote  |  Print  |  Notify Moderator
Atwood vs Suburban
"I'm trying to prevent premature electrolysis from pitting the aluminum. Any thoughts?'
Aluminum tanks don't use anode rods.
Good Luck, Have Fun, Stay Safe
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
Old-Biscuit
Verde Valley
Posted: 11/21/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Bypass Water Heater so any anti-freeze pumped thru plumbing lines does not go into water heater
Then remove Anode Rod (SUBURBAN BRAND ONLY---steel tank)
Drain water heater
Then reinstall anode rod to protect threads from rusting and from spiders/bugs from setting up house
Anode rod 'half' gone......replace with new one next season
billtex
RI
Posted: 11/21/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Check your water heater too
Not sure why you would need a hot water heater?
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
jimh425
Western MT
Posted: 11/21/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I disconnect one pos/negative connections and tape them up individually ... just to make sure that I/wife don’t accidentally turn it on with no water.
If you have an anode, replace it.
Gjac
Milford, CT
Posted: 11/22/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I made a tank rinser out off flexible tubing and rise the tank out when I winterize. There is a fair amount of mineral build up that will come out if you never rinsed the tank before. There is also water in the bottom of the tank that won't drain out that I siphon out with a small plastic tube then put the plug in and blow the entire water system out with compressed air. If you have an electric element in the tank follow Jim's advice. I forgot to do this one year and my electric element burned in half. Half is still in the bottom of my tank.
Old-Biscuit
Verde Valley
Posted: 11/22/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Instead of removing wiring from element just open the 120VAC Circuit Breaker
Or if an Atwood (2004 to present) pull the 2A fuse on circuit board
