RV.Net Open Roads Forum: Truck Campers: Leg supports for truck camper storage
 > Leg supports for truck camper storage
north*mom
North America
Posted: 11/20/20 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
We had our Sunlite truck camper legs sitting on top of concrete blocks for winter storage last year. Last spring while installing the camper back on our truck the rear legs shifted and the rear part of camper ended up falling off both blocks and ended up in a very precarious place. We need to use something as a base as the truck is too tall to just set the camper legs directly on the ground, what do others use for this? I'd like to avoid having the camper fall again next spring!
JRscooby
Indepmo
Posted: 11/21/20 04:20am Link  |  Quote  |  Print  |  Notify Moderator
Maybe wooden box, with a rim so the jack foot can't slip off?
midnightsadie
ohio
Posted: 11/21/20 04:42am Link  |  Quote  |  Print  |  Notify Moderator
same tc made a rolling table. lowered the tc down and could store it any where .
JRscooby
Indepmo
Posted: 11/21/20 05:57am Link  |  Quote  |  Print  |  Notify Moderator
The way I read OP, he does not pass the Lincoln test; His legs are not long enough to reach the ground.
To store, the rolling table is a good idea.
JimK-NY
NY
Posted: 11/21/20 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I lower my camper onto a stack of pallets. I use blocks under the jack legs and keep some of the weight on the jacks as well as the stack of pallets.
towpro
Compass PA
Posted: 11/21/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
what I ready they are saying is because the truck is so high so they put blocks UNDER the camper legs to allow enough room to lift the camper off the truck.
this spring while loading it one of the blocks shifted
What I would do is build a platform where the front and rear blocks are all connected. Remember you only need the front blocks to clear the tires, the rear blocks can be larger. You can still tie the front together with a treated 2X because the truck can drive over that with no issues.
If you build a small deck type platform with all 4 blocks connected, with a good foundation of some sort so they don't sink in I bet it would solve your problem.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
AnEv942
CA
Posted: 11/21/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
There are made made leg extensions with different means to attach, yield 6-8" length. Happijacs style that bolt to existing jack pad or Atwood style where you cut off pad and leg inserts into ext and pins (like tongue jack foot).
Easy to fab if you have means.
/.etrailer.com HappiJac 182495
/amazon Atwood 40302
Our camper projects page
ranholago
MN
Posted: 11/21/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
That is my biggest concern, that the camper will move/twist to the side. Its a worrisome problem for me. I use a small trailer (Zieman) used for golf cart to set the camper on, if its not on the truck. My jacks just "touch" the ground and the camper rests 90% of its weight on the trailer. The result is that the camper is low to the ground, it is secure and getting in and out is easy and steady. I can move the camper any where I want, out of the way in the winter and in position when ready to load. works for me.
Posted: 11/21/20 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Seems like most of you didn’t read the OPs post......
To the OP, I’ve never seen a camper “shift” enough for this to happen.
Possible Solutions: Since we have no idea what actually caused your camper to slip or move in the first place.
1. Bigger footprint blocks
2. Proper raising or lowering procedures
3. Don’t run into the camper with the truck
JRscooby
Indepmo
Posted: 11/21/20 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Is the issue the camper moving at back, or falling off the blocks when it moves? Maybe set wooden blocks on a set the dollies used to move a car in the shop. That way movement would not let it fall.
