RV.Net Open Roads Forum: Gone through 5 water pumps in 2015 cedar creek
 > Gone through 5 water pumps in 2015 cedar creek
jaycmpng
Eastampton, NJ
Posted: 11/21/20 06:52am Link  |  Quote  |  Print  |  Notify Moderator
I am about to install the 5th water pump in my 2015 cedar creek. Two different manufacturers. Each pump has developed a crack in the plastic pump housing. What could possibly be causing this issue? Am considering eliminating the pump altogether, since we winterize by heading to Florida but not sure how. Any suggestions?
Jaycmpng
Mmwtdh
Here
Posted: 11/21/20 07:16am Link  |  Quote  |  Print  |  Notify Moderator
The water lines putting the pump in a bind?
You might try flexible stainless lines for the final connection.
jkwilson
Indiana
Posted: 11/21/20 07:18am Link  |  Quote  |  Print  |  Notify Moderator
I’d try securing the lines so the can put any force on the fittings.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
prichardson
Lafayette, La
Posted: 11/21/20 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like an installation problem. It should have flexible lines both in and out and the pump mounted on a solid surface. Something about your installation is putting your pump in a bind.
jaycmpng
Eastampton, NJ
Posted: 11/21/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I guess I should have indicated that the water pump is never used. We have only camped with hookups. The hoses going to and from the pump are the typical soft plastic water lines. The fittings are not leaking, the actual pump housing develops a crack.
opnspaces
San Diego Ca
Posted: 11/21/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
If it's not binding from the hoses used to connect it, I would look at freeze damage as the culprit. If you truly never use the pump then remove it and cap the two hoses.
Edited my post to say cap the hoses as that would be correct for removing the pump.
* This post was edited 11/21/20 09:50am by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
NRALIFR
Truck Camping Out West
Posted: 11/21/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Are you using a pressure regulator when connected to park water? Some campgrounds water pressure is pretty high.
If you’re not using a regulator at all, that could be what’s causing the pump head to crack.
If you are using a regulator, consider buying a higher quality adjustable regulator with a built in pressure gauge.
If you remove the pump and just hook the water lines together, your fresh water tank is going to fill and overflow.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
Old-Biscuit
Verde Valley
Posted: 11/21/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
opnspaces wrote:
If it's not binding from the hoses used to connect it, I would look at freeze damage as the culprit. If you truly never use the pump then remove it and hook the two hoses together.
And if you do remove pump.....cap off the pump discharge line OR install a check valve between discharge/suction lines so when using City Water it doesn't overfill the fresh water tank
Personally I would Cap the discharge line
Just a simple Sharkbite end cap.
As to the pump casing cracking.
Pump mounting is too rigid.
Pump should have soft washers under each mounting and the screws only tight enough to hold pump in place
OR your 'winterizing' technique (FL) is not happening soon enough and pumo freezes
cavie
Posted: 11/21/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
I'm in the freezing camp. Pump in antifreeze and the problem goes away.
Lantley
Ellicott City, Maryland
Posted: 11/21/20 09:14am Link  |  Quote  |  Print  |  Notify Moderator
Do you live in a cold climate? Are you winterizing the pump?
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
