RV.Net Open Roads Forum: Gone through 5 water pumps in 2015 cedar creek
 > Gone through 5 water pumps in 2015 cedar creek
jaycmpng
Eastampton, NJ
Posted: 11/21/20 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Live in Jersey, but as indicated, we winterize by heading to Florida. The coldest weather the pump has encountered is probably upper 40s, so freezing surely is not the case. The dealer we bought the trailer from tried to tell me the 1st pump must have frozen, but that was the only year the trailer was winterized and I had used the pump to get the antifreeze through the lines so that idea was BS also.
Jaycmpng
time2roll
Posted: 11/21/20 10:18am Link  |  Quote  |  Print  |  Notify Moderator
I would need a picture of the installation and the crack to give an opinion.
675w Solar pictures back up
jaycmpng
Eastampton, NJ
Posted: 11/21/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Can't really provide a picture now since I now have the pump in a small tub to catch the drip. Sorry, gotta keep the basement dry.
And after looking closer it's more of a pinhole than a crack, but it's dripping enough to fill a small tupperware container overnight.
time2roll
Posted: 11/21/20 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a warranty defect with a pin hole. If you have a receipt I would contact the seller or the manufacturer.
Otherwise move on (again [emoticon] ) with a new one.
garyemunson
Reno, Nevada
Posted: 11/21/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have found that just blowing out the lines usually leaves enough in the bottom area of the pump to cause freeze damage. The design of the pump just retains water in low points. I blow out my line but finish off with about 10 seconds of pumping antifreeze into the pump.
down home
south
Posted: 11/21/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Freeze damage is about the only reasonable thing I can think of, too.
9 years on first pump an Aqua flow, replaced with same. Switch went bad on it and they won't sell parts.
Either it was freezing, or anything else, I cannot come up with it.
* This post was edited 11/22/20 03:05pm by down home *
Edd505
Elephant Butte, NM
Posted: 11/22/20 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
5 pumps in 5 years and you don't use the pump. Over tight or freezing, head south sooner.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
CavemanCharlie
Storden,MN
Posted: 11/24/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
My pump is 27 years old. Does it always crack in the same place? At the same time of year ?
Do like Old Biscuit says and just cap it off if you don't use it.
jaycmpng
Eastampton, NJ
Posted: 11/24/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Have installed a shutoff, and shurflo is replacing the housing portion of this pump. No one can explain why. Basically all the pumps have leaked generally in the same place. To those that insist the pump is freezing, this trailer has not seen temps below low 40 upper 30, if that is freezing, I guess we better start wintering in Hawaii.
