RV.Net Open Roads Forum: Truck Campers: Dodge 1999 3500 Lamarie dually
 > Dodge 1999 3500 Lamarie dually
Page of 5
intravino
Quebec
Posted: 11/21/20 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Hello again,
I found a dually in my budget that has 120k miles. The engine and transmission are in very good condition.
The problem is that the original owner had a hitch for a fifth wheel anf he did not care of the box, because of that you have four 6 inches of perforated holes.
My question to you is: does this affect the strength of the bed for carrying around a 4000 lbs truck camper?
Thanks for your time,
Intravino
* This post was edited 11/25/20 06:24am by intravino *
Old-Biscuit
Verde Valley
Posted: 11/21/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
NO....
Might affect hauling gravel, dirt, mulch but not a TC
TC Weight is carried by frame/suspension/axle/tires
6" holes???
Might look into finding plugs for those hole, have some sheet metal welded over them or a salvage bed
US NAVY------USS Decatur DDG31
352
Oxfofd, Fl
Posted: 11/21/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
NO
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
jimh425
Western MT
Posted: 11/21/20 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
4 x 6” holes? That’s pretty crazy. If you mean small holes in 4-6 inches, I think that’s fine. Most people use a rubber mat. I’d add one of those and not worry about it once you make sure the holes are protected for rust?
towpro
Compass PA
Posted: 11/21/20 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
I don't recall how big they were, but the holes in the Dodge factory hitch seemed pretty big with the black covers off. Dealer can sell you new covers, they twist into the holes.
I see your title says 2000, and I don't think the factory hitch offering was until 2003.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
StirCrazy
Kamloops, BC, Canada
Posted: 11/21/20 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
dont think any of the companies had factory undermount hitches in 2000.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
towpro
Compass PA
Posted: 11/21/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
your reply beat me to fixing my post [emoticon].
I know the B&M had 1 large hole in middle
lap527
Ocala, Florida
Posted: 11/21/20 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
Our 2006 Dodge dually Laramine still has the holes when we had our fifth wheel before getting our TC. We haven't had any problems carrying our TC.
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
Kayteg1
California > Nevada
Posted: 11/21/20 11:30pm Link  |  Quote  |  Print  |  Notify Moderator
I just removed plywood who was attached as a shim under my heavy camper.
The imprint generated over the years shows that most of the camper load goes on 6" stripe right behind the cabin and then on 6" stripe at the end of the bed.
Meaning you could remove the bed floor between those stripes and it would not affect camper carrying.
Posted: 11/22/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
If you found a low mile, good condition 20 year old Cummins dually in Quebec, buy it.
95% chance whatever holes you’re trying to describe won’t matter.
100% chance it will be better than 95% of the rest of the old trucks you’ll find up there.
Don’t worry about it.
2017 Heartland Torque T29
Page of 5
