RV.Net Open Roads Forum: Tech Issues: What size?
 > What size?
coolmom42
Middle Tennessee
Posted: 11/21/20 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
...Is the water heater drain plug? Are they all the same?
There are all manner of packs of these floating around. Like THIS ONE.
Are those angled wrenches of any use? I'm thinking mine is going to need a socket extension to get to it.
* This post was edited 11/21/20 08:53pm by coolmom42 *
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Lone Pine, CA
Posted: 11/21/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Always good to have an extra plug but thirteen bucks for a bent piece of metal?
Sjm9911
New Jersey
Posted: 11/21/20 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
There are diffrent ones, look up the make and model of your heater and match it. I use a short extention on my socket.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
IAMICHABOD
Sunny So Cal 90713
Posted: 11/21/20 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
I would try the socket first as I did but it was a no go,So I went with This One and it worked out very well.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
rockylarson
Jersey Shore
Posted: 11/22/20 02:22am Link  |  Quote  |  Print  |  Notify Moderator
The wrench that comes with those plugs has two different sizes. I would think that implies there are two different size plugs out there. At least on the outside. The inside diameter of the drain may be the same on all water heaters. I increased the bend angle on that tool and it worked just fine. Channel Lock pliers have worked also.
Jan and Rocky
Volunteers for USFWS. 25 refuges with 8000 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
craig7h
Branson MO area
Posted: 11/22/20 04:03am Link  |  Quote  |  Print  |  Notify Moderator
I have always used the 15/16th socket, with a small extension.
Itasca Meridian SE 36g
Road Master Tow Dolly
Wherever I happen to park
Posted: 11/22/20 04:04am Link  |  Quote  |  Print  |  Notify Moderator
The Threads are usually 1/2 inch IPT. Atwood normally uses a plastic plug I suggest a six point socket (not a 12) on this plug. Suburan normally uses a metal plug with an anode rod. this one can take any kind of wrench.
page 2: Keep a short length (like 6 to 10 inches) of plastic irrigation pipe, also 1/2 inch thread With water heater cold and pump /city water off. pull plug, thread in pipe open TPR valve to drain (Stand back) pipe takes water out past side of RV. Need not be all that tight. Finger tight will do.
Home is where I park it.
kellem
Shenandoah valley,VA
Posted: 11/22/20 06:49am Link  |  Quote  |  Print  |  Notify Moderator
From the 4 trailers I've owned from various manufacturers, 1 1/16" socket has removed the anode to drain.
Lynnmor
Red Lion
Posted: 11/22/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Suburban uses a 3/4" NPT anode that uses the 1-1/16" socket. Others use a 1/2" NPT plastic drain plug with the smaller hex.
I might add that the tool maker mentioned in the original post has no clue, photos, descriptions and measurements are incorrect.
RAS43
Littleton,CO
Posted: 11/22/20 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Same here, all were Suburban heaters.
 > What size?
