fj12ryder
Platte City, MO
My Suburban also uses a 1 1/16" socket.
Howard and Peggy
"Don't Panic"
Dusty R
Charlotte Michigan 48813
After I drain our's the first time I replace the plug with a ball valve.
Dusty
Old-Biscuit
Verde Valley
Clarification:
Suburban Anode Rod Hex head requires 1 1/16" socket
Drain hole is 3/4" NPT
Atwood can be 2 different sizes depending on Vendor
A 15/16" socket OR a 7/8" socket
NYLON drain plug...both are 1/2" NPT
Tom/Barb
Oak Harbor, Wa
craig7h wrote: I have always used the 15/16th socket, with a small extension.
X 2. one socket is best.
skinny, wrenches will slip, and there seems to something in the way.
MitchF150
Puyallup, WA
Yeah, I used a Sharpie and wrote "1-1/16" on it so I know which socket to grab when I want to remove on my Suburban anode/drain plug.
Mitch
stevenal
Newport, OR, USA
I like to use a 6 pointed socket. Too easy to round the corners off the Attwood nylon plug when using 12 points.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
