Chum lee
Albuquerque, NM
4x4van wrote: One thing that I haven't seen mentioned is tire cost. There is a significant cost difference between 19.5"s and 22.5"s when the time comes (every 5 years). Yes, the 22.5"s carry more weight and typically will ride a bit better, but if the rig's GVWR can accommodate 19.5"s, I don't see a huge downside. I can also change a 19.5" flat on my own (although I certainly won't "enjoy" it); not sure I could do the same with 22"s.
Yes. The OP seems to be oblivious to that. IMO, they are comparing the purchase price of one used vehicle to another. (not the long term operating costs of either) Surprise, surprise, surprise . . . .
Chum lee
last
edited 11/24/20 05:29pm by Chum lee *
View edit history
rk911
DuPage County
4x4van wrote: One thing that I haven't seen mentioned is tire cost. There is a significant cost difference between 19.5"s and 22"s when the time comes (every 5 years). Yes, the 22"s carry more weight and typically will ride a bit better, but if the rig's GVWR can accommodate 19.5"s, I don't see a huge downside. I can also change a 19.5" flat on my own (although I certainly won't "enjoy" it); not sure I could do the same with 22"s.
more like 7-yrs for us. we estimate the cost of a new set of 6-tires adjusted for inflation in 7-years and the divide that amount by 84 and set aside the result in dollars out of our monthly budget. if we want $5000 for new tires we would set aside $60 each month. painless.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Mondooker
Florida Gulf Coast
Hi Chum lee, I'm not sure where you got the idea I was talking about a used coach? I'm looking for new.
My question was is there a reason to specifically look at a coach with 22.5 tires over a coach having 19.5 tires? T
he answer is NO... If you don't need the additional weight, then the tried and true 19'5's work just fine. The 22.5 tires/chassis may give a little better ride, but not to the point to make a selection on it?
Have I gone off the rails on what you good folks have said?
tropical36
Southwest Florida_USA
Mondooker wrote: Hi Chum lee, I'm not sure where you got the idea I was talking about a used coach? I'm looking for new.
Are the two coaches about the same price wise?
Just wondering why the one is equipped with larger wheels.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Chum lee
Albuquerque, NM
Thanks for the reply. In NO WAY am I suggesting that you buy a used coach. If you can afford a new one, that's fantastic. My goal in this post is that you buy the best vehicle for you. I am a (really good) sales person, (well. . . .now retired) and I'm trying to help you through the process. (of buying)
Chum lee
Blaster Man
Get the coach you want, the appropriate tires will be on it. If you want 22.5s that means you'll get a larger coach than one with 19.5s.
2014 American Eagle
Gjac
Milford, CT
Have I gone off the rails on what you good folks have said? You have not gone off the rails your conclusion is correct. One would be hard pressed to tell the difference in ride quality between the two tire sizes on the exact same vehicle. There are a lot of other factors that contribute to ride quality. Get the MH you like the best.
