RV.Net Open Roads Forum: Around the Campfire: Portable Generator
 > Portable Generator
MKDSK
Corinth, NY/USA
Posted: 11/23/20 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Will this generator run my oil furnace, electric water heater, three refrigerators, 1 freezer, garage door opener, lights and tv.
https://www.homedepot.com/p/Generac-GP-8-000-Watt-Electric-Start-Gas-Powered-Portable-Generator-50-ST-CARB-7676/308948046#overlay
miltvill
Ft. Lauderdale FL
Posted: 11/23/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
It will run the three refrigerators, one freezer and garage door opener and tv with no problem at the same time. I don't know how many lights you want to have on at the same time, but it should run all of your lights at the same time. Just turn off the lights you don't need to use. You need to see how many watts the furnace and water heater use. My water heater has two 4500 watt elements. I have a 6500 watt generator. I turn only my hot water heater on for 30 min. This gives me enough hot water. Then I turn other things on.
The more stuff you turn on the more gas you will use. $$$
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
MKDSK
Corinth, NY/USA
Posted: 11/23/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
The water says upper element 4500 and lower element 4500. Where on the oil furnace would it say the watts?
deltabravo
Spokane, WA
Posted: 11/23/20 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Posted in the wrong thread and the wrong forum.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
MKDSK
Corinth, NY/USA
Posted: 11/23/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't matter.
Tennessee
Posted: 11/23/20 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
This in NOT in the wrong forum, ATC is for 'non-rving' topics. Continue on. [emoticon]
Lynnmor
Red Lion
Posted: 11/23/20 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
There should be a plate on the furnace with the specifications. If you can't find that, there should be a tag on each motor showing the running watts. Your water heater will switch between the upper and lower 4500 watt elements, and not run both at the same time.
MKDSK
Corinth, NY/USA
Posted: 11/23/20 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
How do I post a picture here of that plate on my furnace?
miltvill
Ft. Lauderdale FL
Posted: 11/24/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
The water heater can run on the lower watts but it will not come to the full 4500 watts and may take longer to heat up with no damage to the heating elements which is why your water heater will work. The blower fan on your furnace is what is going to use the most wattage in reference to your furnace. Just like the blower fan on a RV furnace.
If you cant find a plate on your furnace displaying the total watts your furnace uses try the manufacture's website. Multiply amps by voltage to get watts.
bucky
Raleigh metro
Posted: 11/25/20 04:49am Link  |  Quote  |  Print  |  Notify Moderator
I think DB meant that he posted in the wrong place, not the OP. I always just use a . when I mess up.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
