RV.Net Open Roads Forum: Have You Installed Your Own Slide Topper?
 > Have You Installed Your Own Slide Topper?
FlashBuddy
Fort Collins Colorado
Posted: 11/24/20 07:05am Link  |  Quote  |  Print  |  Notify Moderator
dedmiston wrote:
I would love slide toppers, but what does everyone do in the winds? We get horrible winds where we camp.
Camp somewhere else and get slide topper from Amazon. Unless you're into windsurfing.
2018 Ford F-250 6.7L Diesel Lariat Super Crew 4X4
Grand Design Reflection 295RL
Jan Baby the Wife & Molly the Dog
CaLBaR
Ontario, Canada
Posted: 11/24/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
1L243 wrote:
I am thinking of ordering and installing a slide topper on my RV. My side measures flange to flange at 7'6" (or 93"). When I go on Solera's site I see the closest topper sizes at 8' (or 96") or
8'6" (or 102"). Would either of these sizes work or would I have to do a special order?
Thanks
I have installed 2 of the Solera toppers to my Reflection. Lippert has a table that should be used to determine the length of the topper needed. You measure flange to flange length and then pick the correct P/N from the table that you find here and it all works out perfectly.
https://lci-support-doc.s3.amazonaws.com/quickreferences/ccd_0001820.pdf
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
kellem
Shenandoah valley,VA
Posted: 11/24/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
I Don't have slide toppers on current trailer but on previous trailer, they could withstand much more wind when compared to an awning......but some flapping is to be expected.
My Colorado toppers were 10 yrs old when trailer was sold.
cummins2014
Utah
Posted: 11/24/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Same here, was in wind ,at times. Yes the one longest flapped a bit, and was annoying , but it never hurt the topper.
pinesman
virginia
Posted: 11/24/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
When my previous trailer was totaled by the insurance company, I pulled off the slide toppers and put them on my current trailer. I had to shorten the tube and awning a little since this is a smaller slide but it was not a big deal
1L243
Oregon
Posted: 01/15/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the information but I have to confess I wimped out. Camping World had the Black 96" Solera on Sale for $280. They charged $135 in labor and another $30 in supplies for the install. They did the install in less than two hours.
They did a great job and I could watch from a distance. The biggest pain was driving the 100 miles to the nearest CW in a major down pour.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
shadows4
Kansas City, Mo
Posted: 01/31/21 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have been thinking of doing this myself also. One thing though, on our door side slide when the awning is deployed I only have 1.5 inches of clearance. The main slide is 152 inches. What size should I use? Thanks.
2003 4X4 F350,CC,SB,Lariat,7.3L diesel, 214,000 miles
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
1L243
Oregon
Posted: 01/31/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Are you saying your current awning will cover your slide out?
If my awning covered my slide out I don't think I would bother with a topper. I would either deploy the awning just enough to cover the Slide out or completely.
shadows4
Kansas City, Mo
Posted: 02/01/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
No, I don't have a slide out awning currently. When I deploy my electric awning the awning arm clears the upper corner of the slide out by 1.5 inches. Not sure if I can even use a slide out awning with those close dimensions.
1L243
Oregon
Posted: 02/01/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Ok, I get it. Typically a Slide Topper is measured outside flange to outside flange. My flange to flange measured 93 inches and I ordered 96 inches. My slide topper sticks out past the slide flange on each side about 3 inches on each side.
You could order your slide topper a little less than the distance between flange to flange. Lets say yours measures 12'6". Instead of ordering larger you could order smaller lets say 12 feet which would be 6 inches less a difference of 3 inches on each side which hypothetically would put you flush with the flange.
Of course you will have to check all your own measurements. And for something that close I would pay to have it done and tell them what your situation is so they can plan for it.
