RV.Net Open Roads Forum: Travel Trailers: 1/2 ton towing
 > 1/2 ton towing
Bkuhl1179
PA
Posted: 11/23/20 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Just purchased a 2020 Ram 1500 5.7 with the etourqe along with a 3.92 rear. Specs on the truck says it has a 1681lb payload and can tow up to 11500 lbs. Looking into purchasing a 2021 Grand Design 3250BH. Dry weight on the rig is 8450lbs and hitch weight is 850lbs. Am I crazy for trying to tow something this big? The numbers seem to be in line with what the truck is rated for.
MarkTwain
Northern, Ca. , USA
Posted: 11/23/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
Have you considered towing up mountains or towing when it is windy??
Bkuhl1179
PA
Posted: 11/23/20 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
I would be mostly doing local towing so no major mountains to get up. Also been looking at the equalizer 4 anti sway distribution hitch. Not sure if that would help with wind at all but if it’s super windy I wouldn’t tow that day. Kind of new into this towing a travel trailer gig. Just looking for opinions.
near Bishop, California
Posted: 11/23/20 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
Why limit yourself to “local towing?” No Rockies, Sierra, Appalachians? You are making too many compromises IMO. No hitch fixes the tail wagging the dog in wind. Adequate TV weight and wheelbase are the only sure cures.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
kellem
Shenandoah valley,VA
Posted: 11/23/20 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Well for starters, you considered dry weight which will never come into play.
Your looking at a 10K trailer minimal with 1200 lb tounge.....there goes your payload once you add a dog and wife.
Tow ratings are very deceitful.
TomG2
Central Illinois
Posted: 11/23/20 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Bkuhl1179 wrote:
...snip... it has a 1681lb payload ....snip..
Not nearly enough payload for that size trailer.
Gdetrailer
PA
Posted: 11/23/20 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you are crazy.
Not sure exactly what the GVWR of the trailer is but I suspect it is well north of the dry weight (10K or a bit higher)..
As it stands, with the advertised dry weight of 8450 lbs the tongue weight is too light for the trailer length and I suspect that tongue weight is heavier than what is advertised..
for absolute best towing stability you want the tongue weight to be right up at 15% and that my friend with the current dry weight would be 1281 lbs!
That's only going to leave you with 400 lbs of available cargo on your truck.. Add in a passenger or two and you are maxed out and we haven't talked about what that trailer tongue weight will be once you put stuff IN the trailer..
You have a trailer which would be far better matched to at least a 3/4 ton..
As a rule of thumb, you will run out of available cargo before you hit the supposed advertised "towing limits"..
Buyers remorse is coming soon..
Bkuhl1179
PA
Posted: 11/23/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Haven’t pulled the trigger yet on the TT. That’s why I’m on here getting opinions.
azdryheat
Tucson, AZ
Posted: 11/23/20 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
I think you'll be disappointed trying to tow that trailer.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2016 RZR 900
afidel
Cleveland
Posted: 11/23/20 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
General advice, cut at least 2,000 pounds from that dry weight and 2' from that length for a better towing experience with a half ton.
/Going to check out a 5,900 pound 34' trailer as soon as we can setup a date with the dealer.
//My truck is nearly identical specs, though a worse rear end
///This is about the biggest we're considering
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
 > 1/2 ton towing
