RV.Net Open Roads Forum: Fifth-Wheels: Ford vs Dodge 4 point fifthwheel attachment
 > Ford vs Dodge 4 point fifthwheel attachment
Goldbrick
Royal Oak, Michigan
Posted: 11/24/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I have Reese 16K Signature 5th wheel hitch that was installed on my F250 Ford. Is this hitch compatible with the dodge factory hitch in bed attachment? IF not can it be adjusted to make it compatible?
MFL
Midwest
Posted: 11/24/20 11:46am Link  |  Quote  |  Print  |  Notify Moderator
If you are asking if a hitch for oem Ford puck system will fit the Ram pucks, the answer is no.
Jerry
stickdog
Somewhere, USA
Posted: 11/24/20 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
You wouldn't want conformity what fun would that be. I purchased a 2017 F350 DWR to replace my 2009 F350 DRW> It didn't come with the puck system so I had a turnball hitch installed figuring I could use my B&W Companion hitch. Got to use half of it, the head was OK but the factory told me I needed a new base.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
4x4ord
Alberta
Posted: 11/24/20 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I had a B&W Companion hitch with the factory puck system for my 2016 F350 and I was pleasantly surprised when I was able to keep it for the puck system in the redesigned 2017 F350. The Ram puck system has a much wider stance than the Ford. I would sell your Reese hitch and buy a B&W for the Ram.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
cummins2014
Utah
Posted: 11/25/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
I am wondering if it just a bedrail type hitch , I couldn't find a Reese 16K Signature with a puck system style . I have the 18K Reese Signature sliding hitch , they have the same head as the Elite, great hitch. I can see why he wants to keep using it. When I bought my Ram ,it had the puck system, so I went with Reese picture frame adapter that fit the pucks ,and enabled me to stay with the Reese Hitch
If that is his situation, he could go with an adapter, there are three of them now, Reese ,Demco, and Pullrite. He hasn't been back, but I have to think that 16K hitch has been on standard rails. I will take another look ,but I don't think Reese sells a Signature hitch that goes in the OEM puck system. They do sell fifth wheel hitches that do, but not the Signature .
MFL
Midwest
Posted: 11/25/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
I agree, I think the original Reese/Ford OEM for pucks was an Elite, and only available as an 18K and a 20 something, maybe 25K? If OP would return, offer more info, we could give better advice. OP seems confused, maybe meant 18K, not 16K, who knows? Maybe doesn't know difference between Sig and Elite?
Stop by OP, give more info!!
Jerry
cummins2014
Utah
Posted: 11/25/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
After further looking , pretty sure the OP has an aftermarket Reese underbed puck system that allows this 16K Signature hitch to be attached, enables a gooseneck hitch or this 16K fifth wheel hitch to be installed , its vehicle specific. This 16K has the four point locking system that only fits that aftermarket . Pretty sure he is stuck with a hitch that only goes on the ford aftermarket.
cummins2014
Utah
Posted: 11/25/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
What I found, I didn't know existed , that underbed Reese puck system, it goes underneath ,would have to require four holes cut in the bed , just like the OE puck system the Ford ,and Ram has now. It appears to bolt up underneath. Its a frame with the four pucks. Part # for the hitch is 30057.
cummins2014
Utah
Posted: 11/25/20 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Part # I believe is 30126 for the underbed Reese puck system for the Ford. I think he is going to have to start over , pretty sure that hitch is also truck specific.
Cummins12V98
on the road
Posted: 11/26/20 05:21am Link  |  Quote  |  Print  |  Notify Moderator
B&W, Be Happy!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
