RV.Net Open Roads Forum: General RVing Issues: Dehumidifier overkill?
 > Dehumidifier overkill?
Raife
Posted: 11/24/20 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
Hello everyone. We have been traveling from Texas to California over the last 5 days and have hit some cold nights. We have been warm without issue with the furnace during the nights but the condensation had been bad come morning. I purchased a small Peltier dehumidifier before we left which is worthless and am now considering upgrading to a 30 pint real unit, but wondering if it is overkill...I have a Grand Design Imagine XLS 21BHE, but there are 5 of us.
This is the unit I'm considering: https://www.walmart.com/ip/GE-Appliances-30-Pint-Dehumidifier/189957689
Many of the suggested units found in the search are discontinued or similar to what I already purchased.
Thoughts?
MFL
Midwest
Posted: 11/24/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Five bodies in that size trailer give off a lot of condensation! A full size dehumidifier will help, but adding a little ventilation from a cracked window and roof vent may be needed.
Jerry
Raife
Posted: 11/24/20 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have found the cracked ceiling vent with the fan going works wonders but it cycles the furnace much more frequently (no wonder since I'm sucking the warm air out).
Trying to find a solution to preserve propane (furnace usage) with condensation control...
bgum
South Louisiana
Posted: 11/24/20 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
The unit you bought is not designed to dehumidify a trailer in use. It will do fine in a stored trailer up to 20 feet. 2 or more are necessary for larger trailers.
You need the 30 pint model and let it run.
ksg5000
Oregon
Posted: 11/24/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Most large dehumidifiers require shore power/generator - probably cheaper to crack a vent and run an electric heater/fan.
Kevin
Raife
Posted: 11/24/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the feedback. General consensus is venting is the route to go.
Thank you.
kellem
Shenandoah valley,VA
Posted: 11/24/20 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Run a ceramic heater and slightly cracked window.....we seldom run the furnace when hooked to shore.
JIMNLIN
Oklahoma
Posted: 11/24/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
We lived in a 30' 5th wheel with a super slide for one winter while the house was being built. The unit was the typical summer time camper with R7 walls..roof....floor.
Condensation was terrible. We tried the vent cracking...window cracking but all that did was make a very cold drafty camper/furnace going 24/7 with wet walls.
I finally bought a dehumidifier which helped but not enough capacity. Bought another and no more wet walls.
That was in the mid '90 and I don't remember brands or sizes but we think they came from a Lowes.
ktmrfs
Portland, Oregon
Posted: 11/24/20 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Thoughts?
not overkill at all. We have a small compressor dehumidifier and use it in cool weather in humid environments. It often will fill the 30 or so pints in 12 hours or less, then taper to filling it every day or so
2011 Keystone Outback 295RE
ktmrfs
Portland, Oregon
Posted: 11/24/20 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
pigman1 wrote:
{snip}
Oh yes you can!
We have a 30 pint compressor driven dehumidifier in our 30 ft trailer. We have been in humid fall weather coming in and out of the trailer soaking wet from the rain and a 30 pint unit WILL keep humidity levels down to a point the trailer is comfortable and windows are dry. Even with 6 people in the trailer in this type of weather dehumidifier could keep up.
MOD'S EDIT: I deleted the rude post that you quoted and then deleted the quote here. (I'm not blaming you for pigman's rude post.)
* This post was last edited 11/24/20 09:23pm by an administrator/moderator *   View edit history
