RV.Net Open Roads Forum: 2011 Thor 33A, With a WF600T inverter
 > 2011 Thor 33A, With a WF600T inverter
mullerm1
Arizona
Posted: 11/24/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
I want to replace my 9 year old WF600t Inverter, Any suggestions on a new brand that all the wires will work OR try to fine a the same one
Thanks
near Bishop, California
Posted: 11/24/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Is your inverter working? If so, why replace?
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
time2roll
Posted: 11/24/20 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yes looks to be discontinued.
If you want to use the existing remote and everything connect the same I would contact WFCO to see if the 5110R would be compatible. It is rated 1000 watts but assuming your loads are light and the 12v connection has a fuse all the existing connections should work. Need to verify you have the physical space including room for cooling air flow.
https://wfcoelectronics.com/product/wf-5110r/
675w Solar pictures back up
