RV.Net Open Roads Forum: Tow Vehicles: DEF Math
Search only in Tow Vehicles
 > DEF Math
JKJavelin
Milwaukee, WI
Posted: 11/26/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
Understanding DEF date code. Not obvious.
DEF date cide
This is why I tend to not buy Peak. WAY too cryptic date code. Why not just use a date?
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 21 Nights
noteven
Turtle Island
Posted: 11/26/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
What we learned in the class 8 world is high EGT's (power demand) result in increased NOx emission which = increased DEF use. In a working class 8 truck that was around 1-2% DEF vs fuel.
If I owned a DEF using pickup I would measure in some DEF fills at the pumps vs fuel used and soon have a rate vs fuel use vs work we are doing today factor to know when to fill the DEF tank.
If I messed up and needed some emergency like, I know all heavy truck and equipment dealers who sell current emissions engines are required by law to stock DEF - truck dealers, ag dealers, and likely yellow construction equipment now too. They are often located along main highways.
That would be the day I would exit a trip and drive around looking for a shopping plaza or China parts store to buy DEF in a cardboard box down aisle 300.
rhagfo
Portland, OR
Posted: 11/26/20 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
15 RAM with gauge at 1/2 a 2.5 fits easily.
X2!
Lantley
Ellicott City, Maryland
Posted: 11/26/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
In my case my DEF use is erratic because my truck is my daily driver. I'm not towing all the time.
Tying to calculate/predict my DEF use based on my driving habits is futile.
Just need a gauge!
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
FishOnOne
The Great State of Texas
Posted: 11/26/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Just need a gauge!
I'm surprised you don't have some form of gauge. I use my truck as a daily driver and notice it uses less DEF during the cold months.
Bottom line after 8 years and 200k miles I never ran out and never had any DEF related issues using only Peak Blue DEF. I use a Ford brand DEF nozzles that prevents over fills that I clean and store it in the zip lock bag it came in. I typically add 2.5 gallons every ~6,000 miles
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
Bionic Man
Colorado
Posted: 11/26/20 11:18am Link  |  Quote  |  Print  |  Notify Moderator
ShinerBock wrote:
Buy from the pump at truck stops. Not only is it fresh and stored in a cool place to last longer, but is also only costs about $2 per gallon.
My dealerships sells DEF. I can tell you that most of it sits out in a hot warehouse or in a hot semi-trailer for ages before being put out in the showroom which lowers the shelf life.
Between the cost savings, and being assured you have fresh, not expired DEF, I don't know why anyone would buy it in a box. Sure, it can be slightly inconvenient pulling up to the truck stop and running inside, but as sensitive as some report the fuel systems are it is worth the trouble.
Filled my Jeep up this week. It gets about 1500 miles/gallon of DEF, granted it is more DD, but is used to tow boats. That 8 gallon tank is nice. Not sure why the trucks don't use a bigger tank.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 11/26/20 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
X2!
One has to use 1 to 1.5 gallons when the tank is full before the gauge even starts to move down. It is very slow at the top and more speedy on once the gauge starts moving.
rhagfo
Portland, OR
Posted: 11/26/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
rhagfo wrote:
X2!
While that may be true, at least Ram thought in give you a gauge. Ford and GM didn’t have them early on, and I am not sure if either has a gauge yet.
FishOnOne
Posted: 11/26/20 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
Me Again wrote:
rhagfo wrote:
X2!
The 11-16 Super Duty's tells you "The exhaust system is OK", "under half full", and two different miles left warnings (don't remember the exact miles left messages). The '17-Up have a digital DEF gauge.
The Ram def usage rate is not linear and will go down at a faster rate once the fluid gets down to a certain level. Not sure if Ford or GM does the same.
FishOnOne
Posted: 11/26/20 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a video on DEF common problems. Crystallization and contamination being a couple of the big problems.
Link
 > DEF Math
