BigDaddy1951
Leesburg, FL
The plastic hose on my outside sprayer in the water bay gets very stiff and makes it almost useless. Has anyone found a good replacement?
MountainAir05
New Mexico
just use the type they use on your sink at home if you have one. This is what I used when they start leaking. Also the one for the shower works also.
https://www.lowes.com/search?searchTerm=kitchen%20sink%20spray%20hose
Wherever I happen to park
This is a standard shower hose (1/2 inch thread) the Indoor shower on my Rig had a metal armored hose (The sprial metal stuff) and that type flexes in all weather. Google found the following EXAMPLE I stress EXAMPLE.
Click Here
Home is where I park it.
Executive
10 seconds with the HOT water on will make it flexible again....Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
MrWizard
Traveling
If it's so cool outside, that the outside shower house is stiff, the only thing it might get used for is muddy shoes & boots,
Not going to wash the dogs or me in those conditions
Radiate The Happy
1997 F53 Bounder 36s
The real reason for what I call the Dog Shower is rinsing the 3" hose.
jeromep
Eastern Washington State
Wow, something I actually have some first hand experience with.
While I love the compartment/service faucet or outside shower concept, it isn't all that well executed on a lot of rigs. The valve, hose, and shower head on my rig were original and old and checked, and very stiff. I went to use it this fall and I couldn't get the hot side to completly shut off, so I had to replace the whole set up. Looking around I found this.
Amazon Link to exterior shower with coiled hose.
There are a couple different version of this for different RV applications, and some color choice.
The coiled hose has a quick release to the faucet. The hose also remains pretty soft in cold weather, run some hot water through it and the hose is very flexible. When done, take the hose off the faucet and put it in a convenient place or compartment. I have two hoses for this faucet, one is for when I'm dumping my tanks and dealing with sewage water, and I have a separate faucet that is kept with my fresh water gear for purposes not related to tank dumping.
If you purchase and install this, it will really give you good utility to that outside shower.
Here is a video of it being installed. YouTube video.
last
edited 11/29/20 07:54pm by jeromep *
View edit history
