CharlesinGA
South of Atlanta, Georgia
I too have seen several Youtube videos of broken springs, one on a 16 ft cargo trailer being used as a camper, another on a 20 ft or so travel trailer, and another on a larger trailer, a fifth wheel if I recall. In all cases the spring that broke was the main leaf, out in the area where it is unsupported by the other spring leaves. I highly suspect the problem is cheap imported products, used by Dexter and Lippert and others. This may be the reason that in days gone by, it was unusual to see a broken spring, as the springs 30 or 40 years ago were US made and from US steel.
Gonagain has broken spring on their cargo trailer conversion.
Grand Adventure breaks a leaf spring enroute to the Canyon of the Ancients
https://www.youtube.com/results?search_query=Broken+leaf+spring+rv
US trailer manufacturers seem to be unwilling to install a quality suspension system on their products, as they regard the whole trailer as disposable and not worth the extra expense of a quality suspension.
I wished I had a trailer with a suspension such as the Australian made Cruisemaster.com.au or the alko.com.au suspensions.
Charles
edited 11/28/20 12:22pm by CharlesinGA *
Slownsy
Most broken springs as said is main leaf, fixed by getting a military wrap springs, ( main leaf supported by second) not a expensive fix, yes I have had broken springs in the past and had to drive hundreds of kilometres with timber wedged between spring and frame held in place with tie downs.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
JimK-NY
NY
down home wrote: Cheap Chinese Springs........
The Chinese make very high quality steels. I think this is another of many examples where the American companies order the cheapest materials and then we think cheap materials are all the Chinese can make.
Lynnmor
Red Lion
JimK-NY wrote: down home wrote: Cheap Chinese Springs........
It does not matter what they CAN make, it only matters when they export cheap junk. If they had a bit of pride in their goods, they would refuse orders for inferior, dangerous goods. Japan produced junk years ago and they cleaned up their act.
JRscooby
Indepmo
Lynnmor wrote: JimK-NY wrote: down home wrote: Cheap Chinese Springs........
When US started to trade with Japan, we gave them junk. That is what they made to match are goods. When The learned we wanted better they made as good or better than we did. Compare cars made in '70s US/Japan.
US makes varies qualities of goods for markets. To assume China does not sell what the customer demands is racism.
memtb
Wyoming
JRscooby wrote: Lynnmor wrote: JimK-NY wrote: down home wrote: Cheap Chinese Springs........
You started with a questionable comment only to far exceed reality with your last comment, to which I respond .....”Horse Hockey”! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
JRscooby
Indepmo
I had a friend that lived in Japan as a child late '40/early '50s. He saved some of the toys he had when came to this country. His "Made in Japan toys where much better quality then the MIJ toys I had. OTOH My Made in USA toys where much better then his. I assume toys where not the only products that met that idea. Do you have evidence to the contrary?
Now do you want to disagree that US manufactures quality levels depends on market aimed at? Are you old enough to remember the Chevette? Did it have the same level of quality of construction and materials as the same years Olds or Caddy?
Now what makes you think China can not make steel or springs of both high or low quality? And that if given a choice, RV manufactures would buy the lowest price stuff?
JimK-NY
NY
A high percentage of what is made in China is made to meet specs provided by the buyers. If the buyers want higher quality and more expensive goods, they will be provided. If they want cheap, that is what they get. RV tires are a good example. There are plenty of quality tires available yet the manufacturers seem to prefer buying cheapo Chinese made tires. The Chinese will continue to provide these because there is a market for cheap.
If an RV is built with cheap Chinese made goods, I blame the RV manufacturer for buying the cheapest parts, not the maker of the parts.
buc1980
houston tx
May be bad luck for me but I got 3 springs broke in 15 years.That was the end. I replace the springs with IS Moryde and no more problems.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
