RV.Net Open Roads Forum: Fifth-Wheels: Cameo slide out
 > Cameo slide out
Petethescot
White Rock
Posted: 11/28/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Cameo slide out issue
Hi All I have a 2008 Cameo F35Sb3 and today one of my slide-outs would not function properly when trying to bring it in. It would move 6 inches then stop I would wait 10 sec and it would again move about 6 inches, after about three moves like this it comes all way in. tried this several times and same results. BTW goes out with no issues. So here are a couple of questions: Is this a bad power connection or is the slide-out motor starting to go. Where would the motor be on a Cameo underneath it is all sealed down there so cannot see.? it is the doorside slide out Would you access it from underneath or inside under the dinning and seating area? thanks for any reponses. cheers Peter
MFL
Midwest
Posted: 11/28/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
It is easier for the slide to go out, than to bring it in. My thought, thing to check, is the circuit breaker, which often has auto reset. It would act like you mention, when under load. These breakers weaken over time, and yours may need to be replaced. It should be close to the battery, likely just inside the basement on the wall.
Jerry
Petethescot
White Rock
Posted: 11/28/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Yes goes out with no issue,
MFL
Midwest
Posted: 11/28/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Follow the positive battery cable at battery, see where it goes. The circuit breaker usually within 3' or so.
Should be another same breaker for the landing gear. Just as a test, you could switch them. Should be same amp.
Jerry
TimnJo
Eastern Ontario, Canada
Posted: 11/28/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Could be your battery isn't fully charged.
2010 Carriage Cameo 36FWS
2018 Silverado 3500HD D/A Double Cab Dually LT
handsome51
Baytown
Posted: 11/28/20 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
If you look underneath the RV on the side with the slide problem.You should see a zipper panel. If you unzip the panel,you will see the slide motor for that slide. But like everyone has said, check out the electrical part first.
SDcampowneroperator
South Dakota
Posted: 11/28/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
Peter,
you do not write if its a just stop and pause ( which indicates an electical issue ) or a mechanical issue
Oir 09 Cameo started the pause issue on doorside slide which indicated motor overload. By extending it an inch then bringing it back in we could eventually close the slide. Eventually the rear gear in the zipper panel mentioned in previous post stripped.
Age and increased friction was the cause as well as poor gear alignment.
Look at these previous threads I made for a cure. Pm me for more
rbw slideout gears ( orphan ) gears again
rbw sideout crown gears stripping
Max
* This post was last edited 11/28/20 06:33pm by SDcampowneroperator *   View edit history
Petethescot
White Rock
Posted: 11/28/20 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Cheers will do.
TXiceman
Full Time RVer
Posted: 11/29/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Petethescot. I sent you a private message.
Ken
Amateur Radio Operator.
Petethescot
White Rock
Posted: 12/10/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Nope two brand new batteries.
 > Cameo slide out
