RV.Net Open Roads Forum: Fifth-Wheels: Cameo slide out
 > Cameo slide out
Petethescot
White Rock
Posted: 12/10/20 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Petethescot wrote:
TimnJo wrote:
Could be your battery isn't fully charged.
Nope two brand new batteries.
Hi Ken
never got it.
Petethescot
White Rock
Posted: 12/10/20 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
SDcampowneroperator wrote:
Peter,
you do not write if its a just stop and pause ( which indicates an electical issue ) or a mechanical issue
Oir 09 Cameo started the pause issue on doorside slide which indicated motor overload. By extending it an inch then bringing it back in we could eventually close the slide. Eventually the rear gear in the zipper panel mentioned in previous post stripped.
Age and increased friction was the cause as well as poor gear alignment.
Look at these previous threads I made for a cure. Pm me for more
rbw slideout gears ( orphan ) gears again
rbw sideout crown gears stripping
Max
Hi SD
As you are likely aware the slide out lifts up a bit before coming in.It feels like a power issue as it is hard to get going and does seem strong enough. it starts to move then it stops even with finger on button I can press button nothing happens, I wait about 5-10 seconds press the button againand it slowly moves again. Once it is in about 12 inches or so it comes in rest of the way ok.
its almost as if I don't have enough power to get it up and moving.
 > Cameo slide out
