RV.Net Open Roads Forum: Quiet heater that doesn’t drain batteries ?
 > Quiet heater that doesn’t drain batteries ?
Page of 6
StirCrazy
Kamloops, BC, Canada
Posted: 12/01/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
free radical wrote:
Look up Espar diesel heater or its Chinese knock off copy which cost much less.
Espar is pricey but well worth the money.
Search YT on how to instal,
I have been watching a series on yuo tube about them. the chinese knock offs of the other design are pretty much the same thing as the real one. are you running one? I am wondering about replacing my furnace with one.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pianotuna
Regina, SK, Canada
Posted: 12/01/20 10:02am Link  |  Quote  |  Print  |  Notify Moderator
There are many vented heaters that use no power. They cost more. Your money, or your life?
Regards, Don
KLYoung
Illinois
Posted: 12/01/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget that you might need to run your furnace to keeps your tanks under the trailer from freezing.
(EDIT: I think you mean "don't" instead of "do forget".
* This post was edited 12/01/20 10:38am by an administrator/moderator *
pianotuna
Regina, SK, Canada
Posted: 12/01/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Replace the return air grill for the furnace with a twindow fan. In my case, that pressurizes the heating ducts and prevents freeze ups. On high fan speed it draws a scant 27 watts.
free radical
Canada
Posted: 12/01/20 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
I have Espar using about two galons diesel a week in winter in small TC.
No problems after five years.
No idea about quality of those chinese made ones,youd need to ask people using those,,
Try Foresty forest chanel for example
StirCrazy
Posted: 12/02/20 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Steve
which size did you end up getting a 2K or 5K.
Steve
CavemanCharlie
Storden,MN
Posted: 12/02/20 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
As a alternative you could get one of these.
https://www.amazon.com/TOHUU-Thermostat-........Y2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
They are made for truckers to put in their sleeper cabs at night. You would have to carry a second type of fuel because they run on diesel. I don't know how noisy they are but, I don't think they are to bad.
There are videos of them on You Tube. Some people put them in their campers. I have thought about it and may do it on my next TT.
Oops, on edit I see that someone already recommended this. Me Bad.
doxiemom11
Victoria TX
Posted: 12/02/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
We have heard "roaring" furnaces, water heaters and they all needed an adjustment to run quieter. Wonder if yours in normal sound, or if an adjustment for the oxygen/propane blend needs to be done. You should ask someone who has camping experience to listen to it outside and inside and tell you if it sounds normal or seems noisy to them.
ICamel
Oregon
Posted: 12/03/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using a Wave catalytic heater for seven years in our RV's. First in a 5th wheel and now in our truck camper. Yes, I use it while sleeping. Yes, I am aware of the risks and choose to use it responsibly.
Hi Don! I'm still alive[emoticon]
There are literally hundreds of thousands of products that can kill you(or not). Just look how many items carry the California Prop 65 warning. Given some naturally occurring chemicals found in the State of California I am surprised no one has insisted that California be labeled as containing “chemical(s) known to the state of California to cause cancer, birth defects or reproductive harm.”
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
pianotuna
Regina, SK, Canada
Posted: 12/03/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
ICamel,
And still recommending an unsafe plan to others.
Page of 6
