RV.Net Open Roads Forum: E rated tire with max psi of 65?
Search only in Tow Vehicles
 > E rated tire with max psi of 65?
BurbMan
Noblesville, IN
Posted: 12/01/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I have Nitto Ridge Grapplers that came on the truck when I bought it used, size LT325/65R18 E 127/124Q.
Every E-rated tire I've ever seen is rated to carry its max load at 80psi, so the first trip out with the camper I didn't even look at the tire, I just aired up to 80. Back home 1000 miles later and I see on the sidewall that the max rating for the tire is 65psi.
Sure enough, the Nitto site says may rating is 3860 lbs@ 65 psi. Anybody ever hear of an E rated tire running at 65 psi max?
These are way oversized for the truck (spec calls for minimum 9" rim width, mine are 8"), but after running them on the highway at 80 psi, then on the beach at 20 psi, and at 55 psi unloaded, the truck handles great and wet weather traction/stopping is at least as good as the Revo 3's I had on the Burb.
I was looking for a reason to get rid of these but haven't found one yet....these are about 50% worn, and next set will be the same maybe a size smaller.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Near DVNP, California
Posted: 12/01/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
That is "different."
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
time2roll
Posted: 12/01/20 10:28am Link  |  Quote  |  Print  |  Notify Moderator
Yes those wide tires often have lower 65 rating.
675w Solar pictures back up
MFL
Midwest
Posted: 12/01/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Where are all the tire engineers when you need them? My wag is that these tires are designed as onroad/offroad, so even though e-rated, a lesser max pressure is best for the hybrid use, that the tread and sidewalls are designed for.
JMO, but I'd not use a wider tire, than what the rim is designed for.
Jerry
BurbMan
Noblesville, IN
Posted: 12/01/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
JMO, but I'd not use a wider tire, than what the rim is designed for. Jerry
I wouldn't either, but these were on the truck when I bought it. I was concerned that handling would be compromised running close to GVWR with the camper on, but that hasn't been the case.
twodownzero
NM
Posted: 12/01/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't get rid of them. I have the Ridge Grapplers on one of my trucks, not one I use to pull or carry a camper, and they've actually been great tires. I would, however, not air them up so much unloaded. Check your door panel for what the original tires used for pressure and back that down some. 35-40 psi is probably more than enough.
IdaD
Idaho
Posted: 12/01/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
The door panel on OP's truck should say 60 front, 80 rear. That's what mine says. I don't generally run at 80 on the rears unless I'm towing or hauling something heavy, though.
2015 Cummins Ram 4wd CC/SB
mich800
Pontiac, MI
Posted: 12/01/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
The inflation sticker is only applicable if running the size/spec tires the sticker is referencing.
time2roll
Posted: 12/01/20 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Yes get the tire weight chart to determine the correct pressure.
ksss
Eastern Idaho
Posted: 12/01/20 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have never run those Grapplers (have run EXO and G2), but you see a lot of them around. That is one wide tire. Drop a size or two and you will probably save a couple MPG.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
