RV.Net Open Roads Forum: Tow Vehicles: Tow Haul Mode
Search only in Tow Vehicles
 > Tow Haul Mode
Posted: 12/09/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
shelbyfv wrote:
I think engaging tow/haul will also keep a good charge going to the trailer battery.
I will have to think about that one!
I think he means higher rpms (theoretically) in tow haul equates to higher alternator output. (like my old Chevy).
But as you also know, the charging systems are quite regulated on newer vehicles and long trips, the rpms won’t be any different on the open road tow haul or not.
2017 Heartland Torque T29
shelbyfv
TN
Posted: 12/09/20 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, what I have read is that with Tow/Haul engaged the alternator is programmed to keep providing a significant output rather than dropping down so much after it replaces the starting draw. This may not be true with all brands or years. I haven't verified if this is the case with my Ford, it's just something I read that I thought was interesting and a welcome feature. I have a little meter I can plug in to the 12V receptacle, maybe I'll investigate the next time I drive the truck.
wopachop
Who run bartertown
Posted: 12/09/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
My 03 silverado would shift really rough on Tow Haul mode. Buddy with the same truck noticed the same thing. Shifted hard enough to make you think it was better to leave it off for that particular truck.
Currently have an 02 7.3 and all it has is a button to ditch 4th gear. Not sure if it adjusts shifting and torque converter slippage.
NRALIFR
Truck Camping Out West
Posted: 12/09/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I can’t recall ever reading or hearing of any effect of tow haul mode on the charging system on Ford trucks. There is however a stationary engine operation ECM mode that can be enabled called Battery Charge Protect. It’s only for supporting heavy electrical loads while the engine is running, parking brake is set, and shifter in neutral. When that mode is enabled, it will increase the idle as needed up to 1200 rpm to maintain the battery voltage while using tools or accessories that are drawing significant amounts of power from the truck.
[emoticon][emoticon]
* This post was edited 12/09/20 05:49pm by NRALIFR *
2001 Lance 1121 on a 2016 F450
Cummins12V98
on the road
Posted: 12/09/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Got it!
I have to say on 10 hour towing my residential frig is right where it was at the beginning of the trip.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rjstractor
Maple Valley, WA
Posted: 12/09/20 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
The transmissions of almost 20 years ago were different animals. The 2005 Chevy I used to have acted similarly. Yes, the button in your Ford just turns off the overdrive.
 > Tow Haul Mode
