RV.Net Open Roads Forum: water heater drain mod
coolmom42
Middle Tennessee
Posted: 12/01/20 10:58pm Link  |  Quote  |  Print  |  Notify Moderator
Visited my son this past weekend and he was watching me fight with the water heater drain plug. He is a mechanical engineer and always tinkering with something... so he said "DON'T have to do that every time you drain it." He got a male NPT to barb fitting, clamped a 3" section of hose on the barb fitting, and clamped the other end of the hose to a small ball valve. It all tucks up out of the way of the door and burner.
Now draining the water heater is just a matter of opening the ball valve.
We also cut some covers for the bins below floor level in the large rear storage area.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
garyemunson
Reno, Nevada
Posted: 12/02/20 03:55am Link  |  Quote  |  Print  |  Notify Moderator
Best to keep a plug so when you pull it to drain, you can insert one of the flushing wands to get the sediment out. A lot builds up in them.
midnightsadie
ohio
Posted: 12/02/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I did this 10yrs ago work fine.
valhalla360
No paticular place.
Posted: 12/02/20 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Depends on the model.
I've always had the combined drain plug/zinc...so you can't replace it with a ball valve without eliminating the zinc...which would be a bad idea.
Of course, once you buy the correct size socket, it's really not much of a challenge to remove unless you don't drain for a few years and it corrodes on...of course a corroded ball valve doesn't open either (or worse, doesn't seal when closed)
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Bobbo
Wherever I park
Posted: 12/02/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I bought a flex-head ratcheting box end wrench.
Bobbo and Lin
Old-Biscuit
Verde Valley
Posted: 12/02/20 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Problem with 'drain valves' especially ball valves.
* water gets trapped inside the ball and can freeze...split ball valve
*after installing one folks tend to NOT remove the set up to properly flush the WH Tank of sediment/scale/crud
*Atwood drain hole is on 1/2" so installation of barb fitting/ball valve chokes the drain down and doesn't allow for good flushing...drains water OK but not the crud
*and do you know what that hose/valve set up is TEMP Rated for?
Water temp/pressure COULD go as high as 210*/150PSI should the t-stats fail
US NAVY------USS Decatur DDG31
bukhrn
Lanexa, Va
Posted: 12/02/20 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
I assume this is an Atwood, as on the Suburban heater, anode rod IS your drain plug, and since you should check the rod occasionally anyways, it's no problem.
2007 Forester 2941DS
2014 Ford Focus
K Charles
Connecticut
Posted: 12/02/20 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know why you would "fight with the water heater drain plug" you just unscrew the plug, maybe 10 sec if you have the socket in your hand.
coolmom42
Middle Tennessee
Posted: 12/02/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is not easy to access. It's behind a gas line, and directly above it is the burner cover, which is a big piece of sheet metal with sharp edges.
Bobbo
Wherever I park
Posted: 12/02/20 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. Standard Atwood, just like the rest of us have. Like I said, flex-head ratcheting box end wrench.
