RV.Net Open Roads Forum: water heater drain mod
mobeewan
Hampton, Va
Posted: 12/05/20 10:20pm Link  |  Quote  |  Print  |  Notify Moderator
coolmom42 wrote:
mobeewan wrote:
She said her son was a mechanical engineer so he should very well knowledgeable about dissimilar metals. As long as the valve has a plastic or brass body she is ok. Steel or stainless would be a huge problem since there would be way more galvanic reactivity. Aluminum and brass are way lower reactivity. Even a plastic valve that could take the heat would be fine.
I did similar with an Atwood WH. Replaced the plug with a brass nipple and brass ball valve. Never had any problem. I could unscrew them if I needed to flush the tank.
I screwed the nipple in and screwed the valve onto the nipple. I had to remove the valve handle for clearance so I could turn the valve to tighten everything. Kept the valve handle in the silverware drawer so I didn't loose it and could find it when needed. I even had about a foot of clear tubing with a plastic hose barb i could thread into the ball valve I kept inside the water heater access door to let the WH drain onto the ground instead of running down the inside of the door.
LOL I have a M.S. in Chemistry and would never put 2 dissimilar metals together without lots of teflon tape.
We flushed the tank thoroughly before putting this fitting in so it's good for a while.
I don't mind taking this out for an annual flush but this makes for a really fast way to drain, which I expect to do 3-4 times a year given my location and travel plans.
A lot of people mistakenly think that teflon tape isolates dissimilar metals from touching each other when used in pipe joints. It is completely crushed between the threads to the point of metal to metal contact and only filling in the voids between the threads so that water doesn't leak from the joint.
* This post was edited 12/05/20 10:29pm by mobeewan *
coolmom42
Middle Tennessee
Posted: 12/05/20 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
philh wrote:
spoon059 wrote:
Lots of engineering and contraptions being used...
All I do is open my low point drains and then open my pressure relief valve to break the vacuum. The water drains right out of the bottom of my trailer, right where Jayco designed it to empty.
Easy peasy, but most importantly... FREE. But hey, engineers like to justify themselves with gadgets. Good for them, I've ever even ridden on a train.
That won't completely empty the WH. You can also flush out the WH when you pull the plug
I've been told that the water heater will not drain through the low point drains. Apparently there is a check valve on the incoming cold line. There must be some reason it won't drain through the low point drain on the hot water line, although that doesn't make a lot of sense to me.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
C Schomer
Pueblo West, Co.
Posted: 12/06/20 12:26am Link  |  Quote  |  Print  |  Notify Moderator
My Atwood WH has a brass Watts 3/4 100 XL T&P with dope on the threads. I put the brass valve in the drain with tape. My 13 year old T&P started dripping and I’ll be looking at the threads very closely when I replace it next week. Craig
Bobbo
Wherever I park
Posted: 12/06/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
It won't drain through the hot line because the intake for the hot line is set high up in the tank. (Hot water rises.) As soon as the tank water level falls below that, it quits siphoning. Draining through the cold line is better, but you don't know just how low the water inlet is inside the tank. Once the water level falls below that intake, it quits siphoning. Another thing is you have to open the pop-off valve to vent the tank so it can drain. That is probably the reason you were told it can't be drained through the low point drains. It is not good for the pop-off valve to be opened like that on a regular basis. It is not an on/off valve. It can lead to premature failure of the pop-off valve.
* This post was edited 12/06/20 10:24am by an administrator/moderator *
Bobbo and Lin
coolmom42
Middle Tennessee
Posted: 12/06/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
I opened the drain, and a hot water faucet, with the water pump turned off. WH drained quickly and down to the level of the drain.
It's not clear to me why you would need to open the pop-off to relieve pressure. There won't be pressure on the system unless the pump or city water connection is active, and it's relieved by opening a faucet.
* This post was edited 12/06/20 10:25am by an administrator/moderator *
spoon059
Just north of D.C.
Posted: 12/06/20 11:21am Link  |  Quote  |  Print  |  Notify Moderator
I haven't measured how much water comes out of the hot line, but it is quite a bit. I might not drain every last drop, but I would guess that I drain the vast majority of the water. Certainly I've drained enough to allow for expansion if the last bit freezes. On my water heater, the fill line is quite close to the bottom of the tank and the agitation of the water as it leaves likely stirs up any possible sediment that is left in the bottom. I just don't see any benefit to spending money and rigging up a series of hoses and valves and do-dads to drain the same water from roughly the same low point. But hey, you do you.
Perhaps on some campers, but not any that I have seen. Its very easy to tell. Next time you break from a camping trip, open both low point drains and break the vacuum by opening up a faucet. Your cold water will drain quickly. If you don't have a check valve, your hot water will drain for a much longer time and come out steaming hot.
Correct, opening the hot water at the faucet or the valve will break the vacuum. I usually open at the faucet throughout the year, but once a year when I winterize I do it at the pressure relief valve. Its faster to drain, and usually its getting chilly outside when I winterize and I don't want to stand aroundl onger waiting. I don't think that popping the valve 10-15 times in its life will damage it. If anything, it would jar loose and sediment that has built up around it.
2015 Ram CTD
2015 Jayco 29QBS
mobeewan
Hampton, Va
Posted: 12/06/20 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
It is a relief valve not a vacuum breaker. The valve is designed to hold a set temperature or pressure. The spring handles the pressure part. It is designed to hold the seat down until the pressure overcomes the design of the spring, then the seat lifts momentarily so the pressure is relieved then it reseats. When you operate the lever on the valve to use it as a vacuum breaker you are over compressing the spring and holding overcompressed until the tank completely drains, unless you leave the lever set and forget to flip it back. Continued cycles of over compressing the spring nd holding it compressed will cause the spring to get weaker and not allow the valve seat properly. So, operating the lever on the valve unnecessarily can cause the spring to weaken and the valve to fail.
spoon059
Just north of D.C.
Posted: 12/06/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Again... I don't think popping the valve 10-15 times in its life will damage it. If you are afraid it will, just don't park on that side of my camper or park uphill. The over-analyzation on this board can get a little thick at times...
But whatever, you can accomplish the same thing by going inside and opening the faucet. Its much easier than rigging up some drain plug and shutoff valve that may or may not cause galvanic reactions with your aluminum tank.
msmith1.wa
Tacoma, WA
Posted: 12/06/20 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
For those that don't think you should open the t&p valve. The instructions linked below from Rheem recommend doing it at least yearly.
T&P valve instructions
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
coolmom42
Middle Tennessee
Posted: 12/06/20 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Atwood water heater, so Rheem instructions are immaterial.
