RV.Net Open Roads Forum: Class A Motorhomes: Best Toad Brake controller Battery
 > Best Toad Brake controller Battery
JCat
Big Apple, SoCal, Big D, everywhere USA
Posted: 12/02/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
On my trip last week I drove my Tahoe around for the week once I got to the destination in Sedona.
When I went to depart on Saturday the Tahoe battery did not have enough power to pump up and maintain my brake buddy.
This is the first time this has happened.
I have 2 brake buddies, a primary and a spare and both said no go.
So I figured I need a new battery.
I was thinking I should get more of a deep cycle so it would last during my trips of 6 to 8 hours. Or go back to harbor freight and get the cheap solar panel to charge the battery while going down the road.
Anyone tried a different type of battery for this application ?
Thanks for the feedback.
JCat & PCat
2004 Mandalay 40D
CAT C7 350 HP
Ava
Vancouver Island. BC Canada
Posted: 12/02/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
Can I assume there is no 12v charge line connected from the motorhome to the toad. That will keep any battery charged while driving the rv.
JCat
Posted: 12/02/20 11:34am Link  |  Quote  |  Print  |  Notify Moderator
yes you are correct, no 12v from RV
willald
NC
Posted: 12/02/20 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
I'd go ahead and get whatever starting battery your vehicle requires. Then, wire in a 12V charge line from your Motorhome to the Tahoe so this won't be a problem anymore with the new battery.
That way, you won't be using your vehicle's starting battery like a deep cycle battery, and ultimately shortening its lifespan as a result. Cars really need a starting battery, not a deep cycle. If you use a starting battery like a deep cycle and deplete it low regularly....Welll, you shorten its lifespan and end up in the spot you're in now.
Find a way to run a charge line to your Tahoe, is my vote.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis
See it here
JCat
Posted: 12/02/20 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
sounds good thanks
Tom/Barb
Oak Harbor, Wa
Posted: 12/02/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
If your Towed is in the key OFF position why would the battery discharge ?
FunTwoDrv
NC
Posted: 12/03/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Just food for thought...we use a Brake Buddy and tow 5-6 days without starting the Jeep. In the 4 years we have been doing this, we have not had any battery issues. I suspect replacing the Tahoe battery will resolve your issue.
And yes, a charge line will certainly eliminate future problems.
Gary
crawford
Dandridge Tenn.
Posted: 12/03/20 08:59am Link  |  Quote  |  Print  |  Notify Moderator
This depends on how many time the brake system is deployed every day If in city you my be using it a great deal using up battery more then you think. Get a charging line be safe.
Change from a c class to a A class Georgetown 07 triple slide
ArchHoagland
Clovis, CA, USA
Posted: 12/08/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
How old is the Tahoe battery?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
RLS7201
Posted: 12/08/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you drove your toad for a week and the battery went dead, you might want to have the alternator checked.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
