RV.Net Open Roads Forum: Does anyone use an aftermarket Tire pressure system?
 > Does anyone use an aftermarket Tire pressure system?
Cougarnewbie
Illinois
Posted: 12/03/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I have Tire Minder and love it. But, it did not alert once until after a tire exploded. It's great for temps and leaking tires.
May All Your On Ramps be Downhill
Posted: 12/03/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
specta wrote:
I had the factory one on my truck disabled. [emoticon]
Not to hijack the thread, but was goin to say the same thing. I programmed out the screen popping up telling me my pressure is too low when it actually is correct!
I actually like TPMS, TPIS, but one thing to remember is yes it will alert you to a slow leak, but it’s never called anyone and said “you’re about the have a blowout in 30 seconds, pull over!”
2017 Heartland Torque T29
jimh425
Western MT
Posted: 12/03/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Interesting that there isn’t “one” brand that seems to be recommended. I guess this thread needs to go longer to develop a consensus.
toddb
az
Posted: 12/03/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a tst507 on the truck and trailer. The sensors can be a bit of a challenge to get on and off the dually wheel(OP didn't specify). The flow throughs are too long for the truck wheel. I have the flow through on the trailer, although 1 now doesn't flow through very well~7yrs old. When I changed tires I ordered internal sensors, they were on back order forever and I gave up. I'd highly recommend that way on a drw although they are pretty spendy in total.
I like seeing the tire temps, I actually shifted some weight around since one front tire always ran ~10* hotter. I haven't had a blow out or flat with the system, just reminders to air back up.
ICamel
Oregon
Posted: 12/03/20 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Count me as another satisfied EEZ TPMS System user. I like that it gives you both tire pressure and temperature information. I have it on all the tow vehicle and trailer tires. I did have to add the repeater as the aluminum frame of my truck camper blocked the signal from the boat trailer tires. It has worked flawlessly with the repeater.
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
deserteagle56
Nevada
Posted: 12/03/20 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I put an aftermarket TPMS system on my 4x4 van because it spends most of its time on dirt roads and I've ruined tires because I didn't know a tire was losing air. Type I got had the sensors that screw on the valve stems; the monitor plugged into a powerpoint inside the van. For 11 months the system was wonderful - at a glance I could see the pressure AND temperature of each tire. Then one day the system started malfunctioning and shortly thereafter quit altogether. The company that sold them (still under warranty for a month!) had disappeared so no help that way. I haven't replaced the system yet but I'm really interested in this topic to see which of these systems work well...and continue working for a few years!
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
billtex
RI
Posted: 12/03/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
The two tire failures I have had with TC on were both leakers; one popped bead, one defective tire (Nitto). In both cases I could feel some squirrely handling starting to happen and I was able to pull over safely. These prompted me to get the aftermarket TPMS.
My experience tells me some advanced notice would have been a tremendous asset in both cases.
Unless you run over a large/sharp object I believe traumatic tire failures are rare with the quality of tires we run nowadays.
IMO opinion TPMS is worth every penny and I won’t haul a TC without it any longer.
The cheap one I bought off Amazon (see above) worked great, gave accurate psi and temps. What have you got to lose? $60?
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
