trailernovice
Mission TX
I discussed need for replacing bumper in other threads...
soooooo, the welder is here with the replacement, thicker bumper...and he measures to ensure it sticks out evenly from each frame rails....then a FLASH of recognition!!! The 'front to back' frame rails of the trailer (Jayco SLX 264BH) are not set evenly under the trailer...one of the rails is about 4 inches closer to the outside of the trailer than the other...put another way, the driver side rail is set about 8 inches from the outside edge of the trailer, while the passenger side frame rail is set about 12 inches from the outside edge
this is factory....nothing twisted or anything
Any ideas why it's designed that way?
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
kmac7800
Richland
Could the driver side of your trailer be "heavier" than the passenger side? Therefore the weight would be evenly distributed? Just an idea.
//KMac
Old-Biscuit
Verde Valley
Call Jayco and get the scoop from them....they spec the frames
trailernovice
Mission TX
ctying in with KMAC's thought...that COULD be....the way its designed:
front bed--dead in the middle
--kitchen, with stove and fridge...driver side
--full-size bunks...driver side
--bathroom and dinette...passenger side
this is a no-slide trailer, so THAT can't be the reason...unless maybe just maybe this design is also used on a trailer WITH a slide??? Just thinking out loud
sure wish I had a firm grip on the answer of why the frame rails are offset from center
mleekamp
Washington, IL
Outside of calling Jayco as already suggested, maybe try and find that model locally and measure it for reference. Stop by the Jayco dealer and ask, maybe take a few measurements on similar or other models
Other than the center of gravity answer, I'm stumped too.
2019 Jayco Redhawk 29XK Class C, Ford V10 E450 with Roadmaster Hitch Mounted Spare Tire holder, Bigfoot Hydraulic Leveling
BurbMan
Islip, Long Island
Jayco makes their own frames and talks about construction here on their blog.
If you think about it, the tongue goes back and connects with the frame rails, so in order for the point of the triangle (coupler) to be in the center, the frame rails have to be equidistant from either side.
I suspect that there is additional framing that you can't see under the coroplast bottom. Don't overthink it, just have the welder pout the bumper on.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
trailernovice
Mission TX
actually, re. the coupler...looked at that...at the very front of the trailer is a plate welded across the front of the frame rails...the rails themselves are not visible...the coupler is (as logic and physics dictate) mounted right in the middle, but it's mounting point is this plate in front of the frame rails...
no way to tell how the rails themselves are configured...they're blocked by the plate at the front and the plastic sheeting under the unit
BurbMan
Islip, Long Island
You missed the point. Yes, the coupler is attached to a plate welded across the front, but those rails that go back from the coupler form a triangle. Look at this picture from the Jayco blog:
dodge guy
Bartlett IL
Sounds like it wasn’t built properly. The frame should be mounted evenly under the box. I would say less than a 1/4” variance side-side. They need to be the same distance as the spring pads in the axles.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Tyler0215
Iowa
If it pulls straight, don't worry about it.
