RV.Net Open Roads Forum: why aren't the frame rails of TT set evenly from the sides?
 > why aren't the frame rails of TT set evenly from the sides?
SDcampowneroperator
South Dakota
Posted: 12/03/20 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
properly built, axles are made with a 1/4 degree camber, 0 to 1/16 degree toe in for alignment. Frame should be square and level in every aspect. Your issue is that the frame is not centered between the body of theunit. Strange. I couldnt guess why its built that way.
mobeewan
Hampton, Va
Posted: 12/03/20 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
As long as the frame rails are spaced evenly until they get passed the axles there isn't any problem. As suggested measure the distance from the leaf springs to the outside trailer wall on both sides. If the same everything should be okay. They may have had to offset the frame rail after the axles because of something going through the floor was going to create a problem.
deltabravo
Spokane, WA
Posted: 12/03/20 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
The welder should be installing a hitch while he's there, that way you have a better place to mount a bike rack instead of the bumper.
GDS-3950BH
DC
Posted: 12/04/20 03:00am Link  |  Quote  |  Print  |  Notify Moderator
"why aren't the frame rails of TT set evenly from the sides?"
Having used Amish Craftsmen on a few things in the past reading tape measures and plumb/level/square are not high on their priority list.
Then watch how fast they attach the floor HERE
And that was before they were "acquired" by Thor which I can guarantee did not increase any level of quality be it in materials or actual assembly.
dodge guy
Bartlett IL
Posted: 12/04/20 05:39am Link  |  Quote  |  Print  |  Notify Moderator
LOL. Every time I watch that video I see something new that I just shake my head at! Kneeling on the freshwater tank, so it's now collapsed after wards. Floor bolt holes drilled at an angle. Gotta love their clean up and inspection at the end!
I can't believe they haven't pulled that video yet.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Lynnmor
Red Lion
Posted: 12/04/20 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Some mentioned engineers or design in this discussion, I don't know where they got the idea that engineering is involved in the building of this level of RV.
Fisherman
Angus, Ontario, Canada
Posted: 12/04/20 07:38am Link  |  Quote  |  Print  |  Notify Moderator
How fast can you get the garbage to the curb and sell it.
Posted: 12/04/20 10:04am Link  |  Quote  |  Print  |  Notify Moderator
trailernovice wrote:
Maybe I haven't been clear....this is a design issue...not a 'manufacturing quality' issue...not a 'it got wrecked, and wasn't repaired properly' issue...not a 'he must have thrown the rig out of alignment' issue..
I was hoping there might be an engineer out there who could provide an explanation...it looks and seems funny to me, but I'm sure there's sound reasoning behind the design
Well trailernovice, I don’t have the explanation, and it’s obvious you’re not going to get anything constructive out of the rvtards on this one. Seems most of them are responding between episodes of incomprehension and unavoidable sarcasm, with a sprinkle of ......I’m not even sure.
Good job rvnetters!
2017 Heartland Torque T29
Posted: 12/04/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I was hoping that you would answer a few simple questions so we could better understand how this thing could function properly.
Classic Lynnmor/Lilwiddis response....some days I’d swear you two are the same people with different IP addresses.
dfm
B.C.
Posted: 12/04/20 10:21am Link  |  Quote  |  Print  |  Notify Moderator
This video has been around for at least 12-15 years. I know I watched it that long ago when I bought a Jayco trailer. I doubt it reflects current process with Thor. I'm sure it is infinitely worse today!!
2015 Open Range 340 FLR
2012 Ram3500 Laramie Longhorn/Cummins
1 DW 1 Furperson
