schlep1967
Harrisburg, PA
Without pulling the coroplast you will never know. They may have had to move one side out to accommodate tanks, plumbing or heat ducts toward the back of the trailer.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Lynnmor
Red Lion
Are the wheels equidistant from the sides? Are the springs mounted to the frame rails and are they equidistant there?
trailernovice
Mission TX
everything frame-wise is straight and true, just as it came from the factory...no collisions, no twists, no rust or weakness...right at two years old...tracks perfectly...
it just puzzles me why it would be designed with the frame rails offset like that
Glenn and Toni
2019 Jayco JayFlight SLX8 264 BH
2019 Ram 1500 5.7 3.21 gears
Reese round bar w/d with sway control
Old-Biscuit
Verde Valley
trailernovice wrote: everything frame-wise is straight and true, just as it came from the factory...no collisions, no twists, no rust or weakness...right at two years old...tracks perfectly...
Call Jayco and get it straight from the horses mouth
What IF's can go on and on and on and on.............
colliehauler
Mc Pherson KS USA
Old-Biscuit wrote: trailernovice wrote: everything frame-wise is straight and true, just as it came from the factory...no collisions, no twists, no rust or weakness...right at two years old...tracks perfectly...
What IF's can go on and on and on and on............. ![scratchead [emoticon]](http://www.rv.net/sharedcontent/cfb/images/scratchead.gif) This ^^^
valhalla360
No paticular place.
Lynnmor wrote: Are the wheels equidistant from the sides? Are the springs mounted to the frame rails and are they equidistant there?
This is probably the most critical point and assuming the springs sit under the main beams, the wheels on one side would sit 4" further in from the side than the other...or one side would have a much longer cantilever from the springs to wheels.
It should be pretty easy to check out as the frame is usually visible where the axles connect.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Full Time spliting time between boat and 5er
trailernovice
Mission TX
Maybe I haven't been clear....this is a design issue...not a 'manufacturing quality' issue...not a 'it got wrecked, and wasn't repaired properly' issue...not a 'he must have thrown the rig out of alignment' issue..
I was hoping there might be an engineer out there who could provide an explanation...it looks and seems funny to me, but I'm sure there's sound reasoning behind the design
Lynnmor
Red Lion
trailernovice wrote: Maybe I haven't been clear....this is a design issue...not a 'manufacturing quality' issue...not a 'it got wrecked, and wasn't repaired properly' issue...not a 'he must have thrown the rig out of alignment' issue..
I was hoping that you would answer a few simple questions so we could better understand how this thing could function properly.
4x4van
California
If the bottom of the trailer is covered with coroplast, then perhaps the frame rails are indeed evenly spaced, and what you're seeing that is NOT evenly spaced is just the bumper mount rails sticking out the back? Measure the location of the leaf springs on either side of the trailer; they have to be attached to the actual frame rails.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
BurbMan
Islip, Long Island
trailernovice wrote: I was hoping there might be an engineer out there who could provide an explanation...
There is....and he (or she) works for Jayco. As was suggested 10 or 12 times, if you want to know why it's like that, give them a call.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
