RV.Net Open Roads Forum: Class C Motorhomes: Interpreting Caster Alignment Specs
 > Interpreting Caster Alignment Specs
chris_diane
Washingon
Posted: 12/13/20 12:21am Link  |  Quote  |  Print  |  Notify Moderator
Just a clarification of caster settings above 5 degrees is only possible with the F53 axle. Shims are installed between the axle and spring allowing greater adjustments for caster. The cutaway chassis (E450, E350) use bushing in the ball joint which can only go to a little over 5 degrees caster. The aftermarket 2 piece bushing can only adjust to 2.5 degrees caster.
Harvard
51.6N 114.7W
Posted: 12/13/20 10:25am Link  |  Quote  |  Print  |  Notify Moderator
In the beginning I created 2 threads, one for the F53 (Class A Forum) and one for the E350/E450 (Class C Forum).
The moderators must have assumed both to be the same and scratched the E350/E450 in the Class C forum. Then the F53 was mysteriously moved from the Class A Forum to the Class C Forum.
shlomyo
15358 wyandotte st
Posted: 02/20/21 11:46am Link  |  Quote  |  Print  |  Notify Moderator
i have 1996 ford e350 tioga rv 24 ft that i want to improve the steering that feels loose on highway,
i got the moog bushings +2 deg upgrade to put more positive caster,
this is my aligment report now, it is going to work?
what else can i improve for better steering driving ?
