RV.Net Open Roads Forum: Truck Campers: New F350 Tremor with a SB Camper
 > New F350 Tremor with a SB Camper
Fish mojo
Oregon
Posted: 12/04/20 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Thinking about getting a new Ford Lariat F-350 CC SB SRW with the 7.3 gas engine. The Tremor package has 18” wheels with 35” Duratrac tires, 2” factory lift, 4.30 gears, and off-road springs and shocks. I think this will come in with around 3600 pound payload.
Do you think you could safely put a 8-11 Northern Lite camper on this? Actual dry weight 2715.
TxGearhead
Posted: 12/04/20 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Yes
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Bishop area, California
Posted: 12/04/20 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
You do the math. Will batteries, water, propane, people, generator, toys/bicycles, food/drink and other stuff add up to less than 885 pounds? Would be too close for me.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
stevenal
Newport, OR, USA
Posted: 12/04/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.fleet.ford.com/content/dam/a........es/2021_Ford_RVandTrailerTowingGuide.pdf
Might want to get the camper package.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Fish mojo
Oregon
Posted: 12/04/20 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like the Guide puts this at 3373 pounds payload. The option selector on the Ford website would not let me select the camper option without kicking me out of the Tremor package, which I really want. Tremor also adds a sway bar. Tire ratings are 3640 pounds. Roughly, this gives 650 pounds below payload. Two people, gear, and water will probably put me over by some amount.
* This post was edited 12/04/20 05:00pm by Fish mojo *
Posted: 12/04/20 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Not impressed at all with a F350 at 3600 pounds of payload. Should be 3,893 to 7,033 pounds.
When I see all the bad a// trucks I know they can’t...just can’t...pull and/or carry much.
* This post was edited 12/04/20 06:16pm by Lwiddis *
specta
utah
Posted: 12/04/20 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
I'd skip the 2" lift.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
Posted: 12/04/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Ford isn’t offering this truck as a heavy TC hauler. It’s offering this truck to pull and lift a big TT...right?
MORSNOW
Mountain Home, ID
Posted: 12/04/20 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Off road suspension means SOFT, it is designed to articulate and float over the whoopties, go with a truck designed for heavy loads instead. Look at the payload of a Ford Raptor, it isn't designed to carry much of anything but occupants, but the soft suspension will soak up the bumps in off-road conditions.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
billtex
RI
Posted: 12/04/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
You should be fine, but do you really off-road or just want the kewl factor?
Eliminate the Tremor pkg and you can get payload ~ 4500# SRW gasser F350.
Maybe look at the FX4 pkg.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
