RV.Net Open Roads Forum: Travel Trailers: Tow vehicle charging RV batteries
 > Tow vehicle charging RV batteries
Williams AZ area
Posted: 12/04/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
What’s for lunch, wanderingbob?
Seon
Lake Camanche, CA
Posted: 12/04/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I bought from Amazon a 20watt solar panel charger/maintainer connected to battery #1 while the trailer powers off #2 battery then next day switch to #1 battery and transfer the solar connectors to #2 battery to charge.
As a backup I carry a 12v charger powered by a 2K generator.
Works for me.
theoldwizard1
SE MI
Posted: 12/04/20 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
blaczero wrote:
How slow is it? Is there a mod you can do to make it charge quicker?
The real issue is how large is your battery bank and how depleted is it (what is its "state of charge" SOC ?)
Sometime around 2000, the entire auto industry switched to "smart charging". Smart charging is when the PCM controls the output voltage to the alternator to limit the voltage to "just enough" to replenish the battery after a start and not left the voltage go so low as to discharge the starting battery.
This means that about 5-10 minutes after starting you vehicle the output of the alternator is about 13.2V-13.4V and there is not much you can do about that !
So if your RV battery is at the end of 25' of wire (actually double that because you have a ground connection) you will be darn lucky to get 13.0V, probably less. You can NOT charge a lead acid battery on that little voltage. USING HUGE WIRING FROM THE VEHICLE BATTERY TO THE RV BATTERY DOES NOT SOLVE THIS PROBLEM !
The only solution is a DC-DC battery charger mounted close to the RV battery. Most can accept voltages as low as 10V-11V and boost them up to the proper voltage (>14V) to charge a battery.
theoldwizard1
SE MI
Posted: 12/04/20 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
old idaho guy wrote:
If you are trying to charge your battery while camping, use jumper cables from battery to battery
A DC-DC charger will do it faster because of what I just described.
theoldwizard1
SE MI
Posted: 12/04/20 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
The 12VDC output on most of today's generators does a poor job of recharging a lead acid battery. You are better off plugging in a AC battery charger.
pianotuna
Regina, SK, Canada
Posted: 12/04/20 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
dc to DC voltage boosting may be the best way to improve charging.
Regards, Don
jdc1
Rescue, Ca
Posted: 12/05/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Dual alternator. Best you could ever do. Some super duties come equipped that way.
time2roll
Posted: 12/05/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Single alternator has plenty of amps. The trick is getting the proper voltage on the battery that needs charging. A DC-DC charger will work excellent for this purpose. Still takes 3 to 5 hours to get a flooded battery from low on charge to 95%+.
https://www.renogy.com/12v-dc-to-dc-on-board-battery-charger/
Also consider some solar. This works all day with no effort. Works in motion or stationary. Does need sun of course. 200 to 400 watts works well for most people. Even if it does not provide all the power solar will significantly reduce generator or alternator run time.
675w Solar pictures back up
valhalla360
No paticular place.
Posted: 12/05/20 10:10am Link  |  Quote  |  Print  |  Notify Moderator
I presume he meant a generator putting out 120v AC power a dedicated charger outputting 12v.
Charging with the truck has a few major limitations:
- Wiring is too small and voltage drop limits both the voltage and amperage that gets to the battery. You can run what are effectively battery cables back to the batteries but 30-40ft of good quality battery cable ain't cheap.
- Multiple connections are prone to corrosion or just general poor connection, so they often don't work well.
- Standard alternators are designed to put out their rated amperage for a few minutes to replace the short but high amp draw from starting the motor. After that they tend to drop way back. You can buy specialty alternators that put out more amps but again, not cheap.
A couple hundred watts of solar is a much cheaper solution and if you are stationary, it still feeds the batteries.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JCK
Ohio
Posted: 12/05/20 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I’ve seen as high as 18 amps going to trailer batteries on start up of truck. And hour later or so still seeing 6 amps. Even if voltage is 13.2 to 13.4 amps is what gets the job done. Sure it won’t fully charge but on a 4 to 6 hour run I’m usually close to full charge.
I’m using AGM batteries with low charging resistance. The charge line on my truck carries a 40 amp fuse so manufacturer has to size charge wire to carry load.
2019 GMC Denali 2500 Duramax
2018 Grand Design Imagine 2500 RL
