RV.Net Open Roads Forum: Travel Trailers: Tow vehicle charging RV batteries
 > Tow vehicle charging RV batteries
time2roll
Posted: 12/05/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Most oem charge circuits are fused at 40 amps so I would just get the 20 amp Renogy (or similar) so as not to open the fuse.
I assume the 20 amp rated output can require 30 amps input.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 12/05/20 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Or add a circuit breaker before the dc to DC device.
Regards, Don
time2roll
Posted: 12/05/20 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Open breaker has the same effect as an open fuse..... No charging.
pianotuna
Regina, SK, Canada
Posted: 12/05/20 05:46pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are automatic circuit breakers--intended to protect the alternator.
01tundra
Middle, TN
Posted: 12/08/20 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I ran a dedicated 4AWG charge circuit from one of our truck batteries back to a 150A Anderson plug mounted on the hitch. Used a Blue Sea 50A battery post fuse on the truck.
Installed a 4AWG pigtail in the trailer that powers a Victron 12/12-18 DC-DC charger.
We now get 25A charge current to our trailer batteries.
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali Duramax
StirCrazy
Kamloops, BC, Canada
Posted: 12/08/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
Sometime around 2000, the entire auto industry switched to "smart charging". Smart charging is when the PCM controls the output voltage to the alternator to limit the voltage to "just enough" to replenish the battery after a start and not left the voltage go so low as to discharge the starting battery.
This means that about 5-10 minutes after starting you vehicle the output of the alternator is about 13.2V-13.4V and there is not much you can do about that !
USING HUGE WIRING FROM THE VEHICLE BATTERY TO THE RV BATTERY DOES NOT SOLVE THIS PROBLEM !
The only solution is a DC-DC battery charger mounted close to the RV battery. Most can accept voltages as low as 10V-11V and boost them up to the proper voltage (>14V) to charge a battery.
if your rv batteries are down this should put a load on the system that the PCM will see and it should increase the output accordingly which would mean the larger size wire should work. where your describing would be when the rv batteries are charged and that wouldnt matter much at that point.
it does still leave the questions on weather the voltage will be the ideal voltage for your batteries where a good dc to dc will let you chose charging profiles, instead of just being in bulk the whole time
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
blaczero
Posted: 12/21/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
This is great, thanks for the images.
pianotuna
Regina, SK, Canada
Posted: 12/21/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
Hi Steve,
No. Even with wire intended to carry 80 amps, I do not get "more charging" from the alternator--unless I put a 150 amp load on the house batteries. As soon as I remove the load charging goes back to being minimal.
